Question about Hitachi 51G500 51" Rear Projection HDTV-Ready Television
Color off for first 60 seconds...
Hi, I have a 4.5 year old 51g500 and just recently when I power it on the color seems to be off for the first 60 seconds and then corrects itself. There is no ghosting or convergence problems that I can see, just a lack of color (especially noticed on the grey side bars) and then voila its ok again. It seems to be more purplish (if i can remember correctly) at first but green is apparent in the regular picture until it self corrects. Should I be concerned or have someone look at it, or is this normal after so many hours of use? Oh and just prior to noticing this happen, I enabled the 'power on when video 2 is detected' feature but when i disable it now the problem still happens.
  • 1,153 Answers
You have three color tubes in this set and they are RED< BLUE, Green, I would check 200v line going to CRT's. You may just have a loose connection. you can move around slightly and see if you see a change. Be carefull thou, not to damage anything else. Check to see if CRT boards are on neck of tube(press upward slightly) Hope this helps
Posted on Sep 05, 2007
51G500 51 in. Rear Projection HDTV-Ready Television went black white why?
It does not have a "color" tube, the model here appears to be a set with 3 picture tubes---do yourself a favor and unplug it and a box if used or a receiver if in the line--wait a bit and power back to see if the units connected will reboot.
Also remember to check all the inputs to see if any have color: if using the cable wire direct to a set hook a DVD etc to one of the rear audio video inputs to see if same problem there.
Let me know what you find--I answer about 400 questions here each week but try hard to help anyone who responds or needs more help.
May 23, 2012 | Hitachi 51G500 51" Rear Projection...
Contrast really dark but seems to improve after the tv has been on several hours
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
Hi. I have a workcentre m24 and on start up it says switch machine off then on, if problem persists call support. the error code is 116-201
Try this: 1. Turn machine off 2. After it has completely powered down, unplug the power cord from the wall. 3. Go back to the front of the machine and turn it on and then back off again (remembering to leave it UNPLUGGED from power.) 4. WAIT 60 SECONDS (Very important) 5. AFTER 60 seconds plug it back into the wall and turn it back on.
If problem persists call for service.
Hope it helps!
Apr 07, 2011 | Xerox WorkCentre M-24 Color Copier
Hi I have a Samsung HLN467W, a 46" DLP TV. And after 50-60 minutes, it starts to flicker white, like lightning flashes. But the whole screen is not blank white, it's more like the images are...
It seems color wheel problem in your tv that gets problem after some time and you hear high pitch noise along with picture flicker.
Color wheel need to be replaced to solve this issue. Required color wheel is available with (click to view image of part and price info) and it is job of qualified tv repairman because light engine will take apart for that.
Hope these info will help you.
Mar 15, 2011 | Samsung HLN467W 46" Rear Projection HDTV
The scooter is about five years old or so, batteries are two years old. Faithfully charged,and well taken care of unit, but, just recently the charger started heating up...very, very hot to the touch...why...
hi, the charger unit is breaking down, Sometimes the batteries can cause this problem but I think you find it the charger, when batteries get older they simply don't hold the charge as much as when new, also the way they deliver power can drop off quicker.
Jan 15, 2010 | Pride Mobility Products Hurricane PMV...
Zenith 60
why is there no answer for this question?
May 29, 2009 | Zenith P60W38 60 in. Plasma HDTV
this is a convergence problem,
well worth fixing
I would have a TV repairman take a look at it.
Jan 12, 2009 | Philips Magnavox 51MP392H Rear Projection...
Bad color
the color multi points are off?
Dec 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Too much red color in the picture
Aug 27, 2008 | Hitachi 51G500 51" Rear Projection...
Hitachi 51G500 51" Rear Projection HDTV-Ready Television Logo
43 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
