Question about LG VX3300 Cellular Phone
Phone is unresponsive
The red light on the side of the phone stays on. If you open the it the screen just says Verizon and none of the buttons work. It just stays "frozen". I took the battery out in order to power it done thinking that that may reset it. No success there. Your thoughts?
  • Sasquatch Sep 10, 2007
    That was it. Some how it ended up getting wet. Thank you very much!
  • 626 Answers
Check the back, behind the battery. There is a water indicator decal on the back. Its white, or red if its gotten wet. If not, try a different battery. Best of Luck.
Posted on Sep 06, 2007
SOURCE:
Xperia play analog not working
You have done your own diagnostics, the problem is the SIM Card. The information on it, is not compatible with the import version of the phone. Request a replacement SIM. If it still doesn't work, try a SIM from a different carrier.
Apr 17, 2017 | Cell Phones
MY BLACKBERRY BOLD 9000 WON'T TURN ON!!! My friend gave me her Blackberry Bold 9000. It's battery was replaced a few months ago but it hasn't been used since then. When I plug it into the wall charger,...
Ok...don't panic. The charger you are using is not compatible. Verizon only works with verizon blackberry's. Non verizon will not work with blackberry and vice versa. This is what will happen. you plug it in and it will boot for a few seconds and then the lightning bolt you see is the charge icon and then a red line in it means that charger is not compatable. Blackberry does make its own charger but there is a "pin" on the plug in that will tell it it is not the right one. Am I confusing you?
Jan 06, 2011 | RIM BlackBerry Bold 9000 Smartphone
My phone is stuck at the loading screen, and it keeps staying at the verizon booting screen.. i've tried taking out the battery, charging it, and pressing the power button, but none worked. help! my phone...
soohyungi Hi it sounds like the phone was doing a software update and it crash . You may be able to get it working again by taking out the battery but not put back on the phone, Plug the phone into the charger. Next I need you to look at the contacts on the phone see if they have any corrison on them. Now take a clean tooth brush one that hasn't been use. CLEAN the contacts and the charging port area . See if there is any dirt in the phone.If you can't get the phone to work go to a verizon corp store and let them take a look at it for you . Software crashes ocurr when thwe phone is in the middle and someone calls you . Hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Nov 28, 2010 | LG enV3 VX9200 Cell Phone
Touchscreen not working buttons working
turning it off doesn't do much if you don't pull out the battery. Turn it off, pull the battery and let it stay out for 45seconds - a minute. then try again. be patient and don't tap the screen until it prompts you.
Jul 24, 2009 | LG KU990 Viewty
Blackberry 8330 unresponsive to push any buttons
you know the track ball was white when you first bought it right? the dirt and oil from peoples fingers dirty it up making it unresponsive. the silver plate around the ball pops out. when you get the ball out use an alcohol swab to clean it off. when its dry put it back in. also you should be able to get a replacement ball and plate from verizon. I know sprint usually carries them.
Jul 22, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Unresponsive touch Lg Dare Touch screen
sometimes you just need to take the battery out and put it back in. If you've already done that then you may need to take it to Verizon and get it updated.
Jul 09, 2009 | LG Dare VX9700 Cell Phone
How do I get the front display to light up when the phone is closed? None of the buttons on the side seem to do it.
Hold any of the buttons on the side down for a few seconds and the outside display will iluninate
Jul 03, 2009 | Verizon Communications Samsung FlipShot...
Screen and buttons completely unresponsive, but phone still rings
i had the same problem n ive only had my phone for a month just hold th top button and the home button down for 10-15 seconds and it should reeboot hope this helps :)
May 04, 2009 | Apple iPhone Smartphone
Verizon LG Chocolate
You have the classic 'white screen of Death' Take it to your service provider. This is a manufactures defect!
Jul 13, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Phone frozen
i took mine to a verizon store...they wanted me to buy a new phone
Feb 24, 2007 | LG VERIZON VX5200 Hands-Free Headset...
LG VX3300 Cellular Phone Logo
158 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
