Question about Amana ACD2232HR Side by Side Refrigerator
Ice/water dispenser not lit or working
We replaced the filter and a couple of weeks later all the lights on the dispenser were not lit, nor was the dispenser working. The refrigerator, freezer and ice maker are working wonderfully. Any help, it just stopped. Thanks!
    Novelist:
  • 87 Answers
I think this is probably just a coincidence that you changed the water filter and a couple of weeks later the dispenser doesnt work. If it failed the same or next day then possibly related but unlikely. The water filter purely affects the water supply line. Does the dispenser (water) make a noise (clicking) when activated. If it does then I would check the incoming water supply. If it makes no noise then you possibly have an electrical fault not providing power down to the water solenoid valve. The way to check the ice dispenser is to see if you first have any ice production if you do then again it could be an electrical control fault. You could check the underneath of the cabinet low level for the wiring connection from the door to see if it is dislodged or damaged however if it is a control issue then I would suggest contacting a good fridge tech. Hope this helps.
Posted on Sep 05, 2007
Ice & Water Dispenser Suddenly Dysfunctional; LED lights, too!
Cory, you sound like you have a bad water valve as well as a bad control board for your dispensor. If you've had any storms in your area in the past 4 - 6 weeks, it's very possible that the storm took both parts out.
We have parts for GE as well as mots other major brands, so please give us a call with your complete model number and we will get your parts out to you right away!
We hope this solves your problem and we look forward to being able to assist you with future issues.
Have a great evening.
Nov 05, 2009 | GE GSS22JF Side by Side Refrigerator
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
FROZEN WATER FILTER - UNRELIABLE TEMPERATURES
About the dual water control valve the side that feeds the ice maker could be defective. Fill the ice maker with tap water and let freeze. If it dumps and does not refill the water control valve will need replaced. Here is a link to the water control valve.
WR57X10032 Water Control Valve
As far as the temperature control here is a link to the Temperature Control Here=>
WR55X10095 Temperature Board Encoder Below are some photos. If I can help answer any questions let me know, Sea Breeze appliancepartsse@yahoo.com 6b49f39.jpg053ba1a.jpg
Jul 28, 2009 | GE Profile Arctica Stainless Steel Top...
Whirlpool water dispenser and ice maker quits
change your water filter its probably full of dirt and plugged
Jun 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Clicking, no water or ice, power problem?
first i wold check the micro switch that the acuator paddle trips next i would replace the watervalves which is the most likely cause of this finally id replace the control bd as some early ges had a promblem with this there is also a solinoid in there for opening the ice chute door but that wouldnt affect the water but may cause a voltage drop if its getting bad id change the water valves the ice is on one valve the door water is on the other
Jan 19, 2008 | Hotpoint HSS25GFP Side by Side...
Water dispenser problem?
grandfunk, by your post, it sounds like the line is frozen over. You will have to do some tests. First rule out the dispenser itself. While someone is calling for water see if you have 120V to the water valve. If you do, we ruled out the dispenser. Behind the toe panel there should be a water line with a john guest fitting going up the door. Disconnect it there and call for water. Catch it with a cup. If the water is flowing there, you might be frozen up in the door. I have found a couple of these models with that problem. If it's not flowing there, behind the lower drawers in the refrigerator section is the water coil tubing. Take a hair dryer and go over it lightly. It could be frozen over there. Check these things first and post back. Catriver.
Mar 19, 2007 | GE GSH25JFR Side by Side Refrigerator
Amana ACD2232HR Side by Side Refrigerator Logo
165 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
