JVC - problem. The turntable does not move, normally when a record is put on turntable and the stylus moved across the record the tt automatically starts moving but nothing triggers this happening.
Most modern day turntables are semi-automatic. You move the tonearm from the rest post
over to the record and the platter will start turning. There is a small microswitch inside
either below the arm base or near. There should be a flat bar connected to the base of the arm
and this will actuate the microswitch. The switch is wired in series to the rotation motor.
Solution: 1. Obviously verify the belt is on. Take off the rubber mat and rotate the platter.
The rotation motor is on the left and it has a small brass spindle. The belt should
be visable through the holes in the platter. If not pull the platter gently up, there will
be some resistance. The belt wraps around a smaller inner ring on the underside
of the platter and the rotation motor spindle. If it is degraded it will be stuck to the
platter or fall apart. Generally there 3 common sizes. ( 21.4 / 23.6 / 25 inch) they
readily available on E-Bay, search term "turntable belt".
2. Obviously check power.
3. Check the microswitch, it should "click", verify with ohm meter.
4. Some turntables have a "cut" or stop function. The arm must return first to rest before
starting again, again the microswitch is the trigger.
I have a JVC L-A11 turntable. I cannot get the metal platter off to replace the belt. Is there any...
(More)
I have a JVC L-A11 turntable. I cannot get the metal platter off to replace the belt. Is there any special trick or release for this turntable?
I have a JVC AL A158BK turntable. Until yesterday, I had only used it for 33 1/3 speed albums....
(More)
I have a JVC AL A158BK turntable. Until yesterday, I had only used it for 33 1/3 speed albums. Yesterday I switched to 45 for singles. The turntable continued to run at 33 1/3 despite the switch setting. Does this indicate a bad switch or is there an adjustment possible? thanks al
