WHERE CAN I GET THESE DISCS? I CAN'T EVEN START THE COMPUTER UP! THE COMPANY IS GONE? CAN I DOWNLOWD THE DISC's ONTO DVD's FROM ANOTHER COMPUTER??? THANK YOU!!!
-   Thanks kieronredmon. The geek squad at best buy said I needed to reinstall the recovery discs. I'm trying to buy them off somone who has them. -   Guest
Hi when you say you cant boot up, do you have any power going to the notebook, i.e. lights, drive firing up etc.,
If you have power and the Windows product key you can use an Windows installation disk to get you up and running. The disk itself doesn't have to be your own as long as the version you use is the same as the product key you own, usually found on the bottom of the unit.
For example MS Windows XP Home
I hope this information helps, if not please let me know
As kieronredmon said, if the computer doesn't power on in any way then you'll need a hardware solution, but if the laptop its able to be turned on and you can install windows with any windows disk, then you only will need the drivers, and you can download them from: http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=479&CategoryID=3&DetailName=Driver&MenuID=1&LanID=0
If you still need the recovery disk, please let me know and will check what we can do to give you the disks.
Please rate me.
why does the netbooks allow games to be played and how can i speed it up on the wi-fi.My netbook...
(More)
why does the netbooks allow games to be played and how can i speed it up on the wi-fi.My netbook runs so slow why is it when its hooked up to the wi-fi connection?
i can not get it to boot of the windows xp installation disk.(this is a bootabl disk) i have change...
(More)
i can not get it to boot of the windows xp installation disk.(this is a bootabl disk) i have change the 1st boot as cd drive yet this did not work and also tried other options like when it first start up pressing the esc key it brings up the menu and gives you the option to select which drive you would like to 1st boot drive selecting cd yet it still does not start from the cd i have also tried external cd rom and using removable drive still no joy so how do i install windows xp or any other OS on cybercom fid2010
I suspect it is the panel which got burnt, i have looked for a panel, can not find one here in...
(More)
I suspect it is the panel which got burnt, i have looked for a panel, can not find one here in Zambia, central Africa.
