Question about Trendware TRENDnet TEW-435BRM 802.11g 54Mbps ADSL Modem Router with 4 Port Switch (NETWTW435BRM)
Win98: Int. connection
My computer won't connect to the internet.. I have dsl. I keep getting a "Illegal opporation" message and then it just shuts dowm the page. what's goin on? why can't I get connected?
    Scholar:
  • 133 Answers
This is not down to your Internet connection. The problem lies with your computer, the "Illegal Operation" is very generic and does not give much insight as to what the problem is. However, it may be down to a virus, or faulty hardware such as memory or a hard disk. The first course of action is to reinstall your operating system. If that does not fix it, it is likely to be faulty hardware, in which case due to the perceived age of the system, you will need to buy replacement hardware or a new system entirely.
Posted on Sep 06, 2007
SOURCE:
My innotab max keep giving an error message 404 which mean not connected to the internet but it is
I too have a InnoTab MAX children's tablet with same issue. Power cycling it, leaving cartridge plugged in/then out, have power plugged in then not, forgetting WiFi connection and re-linking after verifying WiFi is fine from other devices, also standing beside the wireless router all have been fruitless.
Having spent an hour on it last night and almost that long tonight - it's going back to BestBuy tomorrow. If I resolve the issue I'll pay what I did.
Dec 25, 2015 | Toys
Won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
I can not connect to the Internet. I have WiFi connection but can't do anything else
Plug your computer/laptop directly into router. Can you get to the Internet then?
If you CANNOT get to the internet when your computer is plugged into the router, reboot your router. If it doesn't have a power switch, unplug it. Leave it unplugged. Next, you need to figure out if you have another modem for DSL or Cable. If you do have another DSL or Cable modem, unplug that device to. After 5 minutes has elapsed for both devices being unpowered, plug in the DSL or Cable modem to the power source. Keep the router unplugged from power. After your DSL or Cable modem has powered up for 5 minutes, plug your router into the power source. Wait a few minutes. Reboot your computer/laptop. Try the wireless connection again.
If you CAN get to the internet when your computer is plugged into the router. Reboot your computer. Try to connect again. If you cannot connect after rebooting, make sure you are connecting to YOUR OWN wireless access point and not someone else's.
Do you have other computers/laptops/wifi devices that CAN/CANNOT connect to your wireless / access the Internet?
Jul 03, 2011 | Computers & Internet
The internet is down the dsl light on the modem is blinking red
I experienced the same problem yesterday with my modem,the internet is down as a result of the fact that the computer doesn't recognize the remote modem,hence the dsl light blinks red,when the internet is up the dsl lights should blink green,the problem is mostly from your internet provider,few times from your computer.
The solution is so simple;
1.Remove the modem from your computer.
2.Shut down your computer.
3.Turn on your computer again after at least 3mins.
4.Insert the modem in your computer and connect to the internet.
5.It might take up to a few attempts before it gets connected to the internet.
Problem solved.
Dec 02, 2010 | AT&T Computers & Internet
Conflict message
if u have 2 PCs connected to the hub/router then you must specify the IP address in Network Connection wizard..../ LAN properties / TCP-IP setting Tab......set each PC different....IP address
say like this.....
192.168.1.3 for 1st PC
192.168.1.5 for 2nd PC
the rest of the settings is based on you internet service provider
this will work....
Jul 15, 2010 | NetGear EN104 Networking Hub
The internet connection is fine (DSL AT&T).
1. You may have a an IP address conflict.
2. check the device connected to the router
all computer need to be connected at the same time.
3. Bring all the computers up one at a time and this should resolve the address conflict.
May 16, 2010 | Linksys WRT54GX4 WIRELESS 802.11G...
Getting online
The phone jack on your laptop is used for Dial-up only, i.e.… AOL, EarthLink, etc….
If you’re trying to connect to the internet via Verizon DSL, then you need to connect to a DSL modem just like your PC is. On your laptop you’ll find another jack similar to a phone jack but a little bit wider. This is a 10/100 Base T connection used for Broadband or Hi-speed internet that you will use to connect to your DSL. If you want, you can take the internet cable from the back of your PC and try plugging it in to your laptop. You will need to power OFF and ON the DSL modem you that it will search for the IP (internet protocol) address of your laptop.
Hope this helps. If you have any other questions please contact me.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Oct 19, 2008 | Dell Latitude D600 Notebook
I have a Imation pocket flash drive and I'm trying to copy music files from my old computer (Windows 98) to my flash drive and I keep getting error message "unable to write". Any suggestions?
You need a driver for the flash drive to work in Win98. You can download it here:
http://driverscollection.com/?file_cid=393499707811d1cd9a955402f23 - if your win98 computer is connected to the internet use it to download the file, then your flash drive will work
Apr 06, 2008 | Computers & Internet
Problem with connection to router and DSL
I would go to run and type in cmd. then type in ipconfig, I believe that is right for windows 98. I would look on there and see if that is getting a correct IP and if the DNS server says 192.168.0.1 if it is a belkin router. ipconfig /? will give you the commands you can use with that. There is a ipconfig /renew that will refresh them all. You might have it set to be a static IP and you would want it to be dynamic and have it refresh by itself. You can go to http://hippo.colorado.edu/info/ipsetup/staticip_setup.cgi?os=win98 for directions to change it to dynamic, I would just do the opposite of what they suggest to make it auto config. It sounds like it is looking for a previous DNS server which is not there anymore because the DSL connection reset.
Dec 20, 2007 | Belkin (F5D7230-4) Router (587009)
Trendware TRENDnet TEW-435BRM 802.11g 54Mbps ADSL Modem Router with 4 Port Switch (NETWTW435BRM) Logo
81 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
