Question about Hitachi 43FDX15B 43" Rear Projection Television
No power The red led light is on and you can hear a faint click if you hit the power button but no picture, no sound and no input appear. TV has worked fine and then just stopped. I unplugged it and gave it the rest for a reset but to no avail. Where do I go next? I am handy and willing to attempt any repair. Just need to know what to look for. thanks Dr. J. A. Lewis
    Genius:
  • 1,153 Answers
Well Dr. Hitachi has a sequence of L.E.D lights in back of set that lights up in accordance to what is wrong with set. there are about 8. so you need to first get someone to turn on and while looking notice which lights up first and goes out first. This tell the tech what is wrong with set. From my experience with Hitachi, I have replaced many Convergence amps which are the big STK's392-*** or something close to this depending on the set. But it most of the time gives some kind of indication before going out. Like color problems not matching up. Red, Blue or Green out of line, mostly on corners of set. If no color problems then next would be sound problems, and vertical problems. Either problem will give a no High Voltage problem like yours. Also it has little pica fuses, sometimes yellow in color. These can be open also. There are many areas to check but if you are willing you can find the problem. Remember to be safe at checking anything with set plugged in. Turn off first. Hope this helps!
Posted on Sep 05, 2007
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung TV (model UN40H6203AF) 40" LED. No picture, have sound. Flashlight test can see faint menu screen. Have replaced power supply & main boards to this point. Ideas as to what to do next?
Hi Terry,
If you can see the faint picture in flash light means the power supply and the main board is working. The real culprit is the backlight. Even one bad LED in the backlight will switch off the whole array. To repair this fault the panel has to be opened and the defective LED or LEDs are to be replaced.
This is a complicated, delicate and risky job and must be attempted by an expert only. You may end up damaging the screen permanently if you have not done it before and try to DIY.
Oct 13, 2017 | Samsung Televison & Video
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
No picture, no sound, no lights, faint clicking sound, fuse ok
HT transistor, or rectfying diode from chopper transformer is blown.
Apr 24, 2009 | Samsung DynaFlat TXN2668WHF 26" TV
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
Sanyo DS24425 TV Has No Picture and Very Faint Audio
DONT BUY SANYO ELECTRONICS THEY ARE JUNK
Jan 09, 2008 | Sanyo DS24425 24" TV
TV won't come on!
Most likely, this is a problem with the convergence board. The convergence amps (STK392-040 x 2)are internally shorted. These can be replaced or the whole convergence board can be replaced. It's cheaper to replace the amps, but more convienent to replace the board (especially for the less electronically inclined!! :) Also, this could be from a leaking CRT. In CRT projection televisions, the red, green, and blue tube are filled with coolent (glycol). These 42" models are very bad about the tubes leaking (Akai and Samsung models)and are infamous for destroying the CRT driver board connected to the bottom of each tube. When this happens, the protection circuit kicks in and will not let the television start up. *PLEASE, FOR YOUR OWN SAKE, DO NOT FOLLOW THESE NEXT STEPS IF YOU HAVE NO UNDERSTANDING OF ELECTRONIC EQUIPMENT!!!! There are four screws and three snap clips that hold the bottom on. UNPLUG THE TELEVISION, remove the screws and pull bottom outward to remove. The bottoms of the three tubes should be visible. DON'T TOUCH THEM!! Now look under each tube. If one is leaking, there will be a wet spot (or sometimes a puddle!) underneath the tube. This will have to be serviced by a TV tech. Hope this helps...
Jan 26, 2007 | Akai PT4799HD Rear Projection Television
Hitachi 43FDX15B 43" Rear Projection Television Logo
81 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
