Question about Car Audio & Video
Sony CDXM 8800 Xplod Car CD player won't repond when buttons are pressed
Hi there, I purchased a Sony CDXM 8800 CD / Radio player for my car this time last year. This was purchased though eBay and the unit was brand new, now out of warranty unfortunately. The headunit hasn't been working properly for approximately the last month. At first it started to 'go' (please excuse the technical terms!) a little strange, by not allowing me to use certain functions such as the up / down volume button or to skip a song forward etc. Now I can only use the remote control to access any of the functions, as none of the buttons on the headunit (when the motorised flip down front is open) work or respond. I could probably get used to this being the only way to use the cd player however the remote control doesn't have an eject function and unfortunately for the last month Justin Timberlake has been stuck in there on repeat, much to my shame, as I'm a hard dance fan! I was wondering, if perhaps you might have heard, if this is a common fault in these CD players or if there is any way to repair them? When the front opens by the remote control, the unit lights up but none of the buttons work, then the light will flicker and go out. It seems, like something that relays the information from the fingerpad to the back of the unit has broken. All graphics on the screen are working when the unit is closed. I hope you can help? With thanks, Karen Ireland
  • 1 more comment
  • Anonymous Feb 28, 2008
    Same problem but no Remote!
  • ghengst Mar 18, 2009
    I have the same problem with my Sony CD/Radio player. The unit only fuctions with remote. I have a CD in the unit and it won't eject it either.
  • videoguybob Apr 30, 2009
    I have the same problem with the same radio. I tore it apart tonight and found out the ribbion cable that connects the flip panel with the body, broke all the way off. If you still have lights then it isn't broken all the way yet.
    I'm trying to find out if a new cable can be ordered from Sony.
    I'll let you know.
    Bob
    Scholar:
    New Friend:
  • 88 Answers
There is a reset button on the area behind the faceplate. You will have to go back in and redo many settings but just hold the tiny button down with a ballpoint pen for 15-30 seconds and it should reset allowing the faceplate buttons to operate.
Posted on Mar 01, 2017
SOURCE:
MrLard
  • 94 Answers
SOURCE: Faceplate not responding / acting very weirdly
Sounds like a bad connection with the faceplate and the multi connector that the faceplate mates with when closed. check for dirt and bent pins on both connectors. Luck
Posted on May 04, 2007
  • 883 Answers
SOURCE: Unable to eject cd magizine. Error 2
power off. open the cd changer unit. look for the motor that, when turning, performs the eject mechanism. now turn this motor by hand in the proper direction until cassette is fully ejected.
Posted on Jul 23, 2007
lobsterman72
  • 91 Answers
SOURCE: CD Stuck in cd player
There should be a reset button on either the face of the player or under the faceplate if its removable (tiny black button). Otherwise to remove the cd disconnect the unit and then plug it in or remove the memory fuse or battery lead for 5 seconds.
Posted on Jul 06, 2008
  • 108 Answers
SOURCE: system lights up - stuck in demo mode - sometimes CD player plays
if detach face may not be making good contact try removing wipe connections w/rub alchol and put back on
Posted on Mar 26, 2009
  • 3 Answers
SOURCE: CD stuck in CD Player - 1998 Mazda Protege
It might be a Bose system. I usually remove stuck CD's by grasping the edge with a pair of tweezers and pulling slowly, there will be some resistance. Try to reset first by removing the fuse for about 30 seconds and after it powers up again (don't turn it on yet) push the eject button.
Posted on Apr 20, 2009
Display not working after installation
If everything else seems to be working, the display may have failed.
Jan 23, 2018 | Sony XPLOD CDX-GT200 CD Player
How do i reset my clock on my sony xplod cdx gt24w car cd player
To set the clock:
Press and hold the select button until the setup display appears.
Press the select button repeatedly until "CLOCK-ADJ" appears
Press SEEK + (the hour indication flashes)
Rotate the control dial to set the hour and minute. (To move between hour and minute, press SEEK + or -)
After setting the minute, press the select button and the setup is complete.
To display the clock, press the DSPL/SCRL button.
Mar 15, 2011 | Sony XPlod CD Player w/MP3 Playback...
Sony explod won't turn on after car battery was disconnected
this unit has a detatchable face take it off by pressing the button on the bottom left corner and take a pen and push the RESET button located near the connector on the unit than put the face back on and press the SOURCE button this should fix it and turn it on note you will have to set the clock as well as all radio presets and sound settings
Dec 13, 2010 | Sony XPLOD CDX-GT200 CD Player
How to record a cassette from cd on a sony xplod boombox cfd-g505
Insert a tape.
Select the program source you want to listen/record (CD).
Insert a cd, press stop.
Press record on the tape player.
Press play on the CD player.
The volume control or any audio emphasis buttons will not affect the record level.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDG505
Mar 17, 2010 | Sony CFDG505BLACK Xplod CD Radio Cassette...
I can t figure out how to connect my radio up like i got the cd player to work just fine but the radio doesn t work
Press the source button to select fm, press and hold BTM button until Btm flashes. This will automatically store stations for you. Page 8 in this users guide covers same as well as manually setting stations. You do have the antena connected?
http://www.docs.sony.com/release/CDXGT20W_200.pdf
Oct 23, 2009 | Sony XPLOD CDX-GT200 CD Player
I don't know how to set the preset stations
Radio:
To receive store stations(press); store stations (press & hold). Preset tuning is not possible, however one can store the correct frequency in the memory.
Manual storing:
while receiving the station that you want to store, press and hold a number button(1 to 6) until "MEM" appears. The button number appears in the display. PS: If u try to store another station on the same number, the earlier station will be replaced by the new one............................................sodeep
May 24, 2009 | Sony XPLOD CDX-GT200 CD Player
Stolen faceplate
the GT-200 is the cheapest of the sony line. A new radio can be obtained for under $50. A faceplate direct from sony would be approximately the same amount. Check eBay or Craigslist for a used one.
Dec 21, 2008 | Sony XPLOD CDX-GT200 CD Player
CD PLAYER NOT WORKING
I would check both of the in line fuses on the on the wire harness on the back of the radio good luck the other thing it might be is a security feature tha may have the radio locked up good luck....
Dec 01, 2008 | Sony Xplod CD Player w/MP3 Playback...
How to set time on sony CDX-GT50W
press and hold the volume control dial. when a menu appears press the volume control button until clock adj appears. then press seek to change from hours to minutes. to adjust the hours and minutes just rotate the volume control dial
Apr 22, 2008 | Sony Xplod CD Player w/MP3 Playback...
Car Audio & Video Logo
1,818 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
