Question about Motorola Mobility SLVR L7 Cellular Phone
Buttons not working
Every now and then I have several buttons on my phone that will not work. They are the down arrow, camera, right soft key and the 8. Its always the same ones at the same time. Turning phone off and removing battery does not work. I just keep pressing until they do or hit it against the wall (frustration did set it that time).
    Brigadier General:
  • 7,752 Answers
You need to have the keyboard replaced.
Posted on Jun 04, 2008
Casio Exilim EX-P505 the left arrow key doesn't work. is it setting or broken? what should i do?
Most likely the arrow key switch is broken or the contacts are corroded. If it's a snap-button switch, it needs to be replaced. If this is bad, I recommend replacing the others also. If it's a conductive rubber button (like most TV remote controls), the conductive patch on the inside is worn and needs to be repainted with carbon/silver conductive paint. A miniature snap-button switch is generally less than a dollar from Mouser Electronics - soldering skills are required for replacement. Conductive paint for rubber button switches is $10.45 for a 1 gram tube. It has a very limited shelf life once it's opened, so use up the rest on the other camera buttons, and the power, channel and volume buttons on your favorite TV remote control (if you can get it apart without breaking the case)
Cameras are typically difficult to take apart for repair. You'll have to consider the value of the camera versus the effort to get to the control buttons. The electronics inside are sensitive to static electricity damage, so you should work on an anti-static mat and use an anti-static wristband with it..
Nov 14, 2017 | Casio Exilim Pro EX-P505 Digital Camera
How do I set the time and date on a Panasonic DMC-LZ4
1. Press the menu/set button. This will bring up a menu.
2. Press arrow left (the button left of the menu/set button).
3. Press arrow down (the button below the menu/set button). This will select the setup menu (so, a wrench icon should be brighter than an icon of a camera).
4. Press arrow up or down (these buttons are above and below the menu/set button respectively) to highlight clock set.
5. When clock set is highlighted press the right arrow button (button right of the menu/set button).
6. Press right or left to select what settings you want to change.
7. Press up or down to get numbers according as you want them.
8. Repeat 6. and 7. as desired.
9. Press menu/set several times to exit menu options.
Feb 28, 2011 | Panasonic Lumix DMC-LS80 Digital Camera
The kx-tga510m phone displays "ringer off". How do I change it to get the ringer on?
To change the ringer volume, press the conf/ function button.
Scroll to ringer setting using the up and down arrow keys.
Press the right arrow key to enter.
Press the right arrow key again at ringer volume.
Press the up and down arrow keys to adjust the ringing volume
Press the save soft key to save entry.
Sep 30, 2010 | Panasonic KX-TG5100 Cordless Phone
How to change the time one hour ahead
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press soft key "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press soft key "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press soft key "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press soft key "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press soft key "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Mar 18, 2010 | Nortel Norstar 16-Line PBX Speakerphone
Soft/hard reset combination keys doesnt work for nokia 6280
try this for soft reset
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Mar 06, 2009 | Nokia 6280 Cellular Phone
Retrieving data from v330 with no screen
i) send out to a cell phone repair and they will print out contacts., will cost u $25-$50.
ii) hook up bluetooth to your pc (check your manual or one online) and download the numbers. this is pretty tough without see stuff on the screen, imho.
iii) check manual (online or yours) to save all contacts, at least as many as possible onto your sim card.
this actually just happened to me a week ago, but i have a backup prepaid v300, so i can put my sim in there for contacts. good luck!
Sep 05, 2008 | Motorola Mobility V330
Uniden 5.8 powermax
From the base unit, press the "Menu" soft key.
Press volume up/down button to highlight "Global Setup" and press "Ok" soft key to select it.
Press volume up/down button to highlight "Day and Time" and press "Ok" soft key to select it.
Press volume up/down button to select the day of the week and then press the right arrow soft key.
Press volume up/down button to set hour and then press the right arrow soft key.
Press volume up/down button to set minute and then press the right arrow soft key.
Press volume up/down button to choose AM or PM and then press the SAVE soft key.
You will heart a confirmation tone.
Hope that helps,
Ken
Mar 17, 2008 | Uniden TRU8885-2 Cordless Phone
No instruction manuel
Hope that helps,
Ken
Jan 19, 2008 | Uniden TRU8885-2 Cordless Phone
Camera problems
you can do a software reset.......to do this the phone needs to be off. press the soft keys (buttons with the lines on them above the back arrow and home button) and press the power button and keep you fingers on the soft keys until a black screen with white writing pops up....by pressing the green call button here, it will reset the phone.....good luck!
Dec 31, 2007 | T-Mobile Dash Smartphone
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
Motorola Mobility SLVR L7 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
