Question about Mitsubishi VS-7085 70" Rear Projection Television
Mitsubishi Model # VS-7085
Video jumps and seems to loose sync. when image is all white ie: 100% ire.
    Genius:
  • 1,153 Answers
It sounds like vertical jitters:INSTALL VERTICAL JITTER KIT, PART # KIT-V14VJ . If it gets bright and shutdown then:. CHECK THE VALUE OF R9A45 (180 OHM 1/2W RES.),IF OPEN OR INCREASED IN VALUE CHECK FOR A LEAKY OR SHORTED C9A57 (1UF 350V).AT THE CATHODE OF D9A07,ON THE MAIN-PCB.
Posted on Sep 05, 2007
SOURCE:
I HAVE A MITSUBISHI VS 7085 TV NOT POWERING UP AND WHERN PLUG ON HAERING A CLICK SOUND
if ya ever found out the cause of this please email me as i am going through the same thing with the exact same model my email is [email protected]
Feb 19, 2010 | Mitsubishi VS-7085 70" Rear Projection...
What causes the image on the screen to jitter
Sounds like bad convergence ICs. They are complicated to replace but a good tech should be able to do it for about $100. Let me know how this works out.
hardrocko
Jan 31, 2010 | Mitsubishi VS-70705 70" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
S.O.S anyone out there
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 03, 2008 | Mitsubishi VS-55705 55" Rear Projection...
I have a Mitsubishi MDT4025 it goes on but i'm not getting a picture
What can I do to get this fix without taking it to the repaire shop?
Dec 01, 2007 | Mitsubishi VS-7085 70" Rear Projection...
Mitsubishi ws65909
Yes,but first it is necessary to repair the problem = replace
both STK392-570 IC's.............Then use remote to adjust
convergence............."inside the tv" is called servicer menu = adjust after repair is complete.You can expect to replace IC's
every five years or so.......................T.
PS Try to match your problem thread model # to actual model #
ie. VS-5043 does not match WS-65909........T.
Nov 25, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Picture "jumps" at startup for about 20 minutes until warm.
You have some leaky filter caps. They are: C2C52 = 10 MFD 50 VOLT (off the base of Q2C51 on the signal board)Also check C2P05 = 100 MFD 16 VOLT (off pin #3 of IC2P01 on the signal board) and C2P03,C2P08 = 100 MFD 16 VOLT both on the signal board.
Sep 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
148 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
