Question about DeLonghi EC140 Espresso Machine
Delonghi EC 140 Espresso Machine
New out of box, first time trying to use Turned on, primed for appropriate amount of time to allow to heat, etc., water is just not flowing to espresso filter. It flows to the steamer. I am pretty sure a hose is just not connected correctly, or is jammed, however I don't know how to get inside the machine to check. When using the steam dispenser, everything works fine -- water is sucked from reservior, and sent to steam dispenser. However, when attempting to actually make espresso, machine runs but no water is pulled from reservoir or run into espresso filter.
Re: Delonghi EC 140 Espresso Machine
Return to store or company..don't open machine or warrenty will be voided
Posted on Sep 26, 2007
0 characters
3 Points
Delonghi EC 820B leak from the bottom edge of the Boiler outlet/ Infusion assembly.
the hose has become clogged up with deposits and split.. you can try to take apart and repair yourself or look up your local shop for repair
Jun 10, 2016 | DeLonghi EC820.B Black Pump Espresso...
Delonghi EC 155 does not make coffee even after I put new filter
DeLonghi EC155 Espresso Machine so what does it do?Possible nothing,and do you know your last time you ran vingar though it to CLean it out?Normally solution is Vingar depend on size put 1-cup Vingar,half cup water,run it though.then run only water then next step in full pot,do this twice.Should work fine.
Aug 08, 2010 | DeLonghi EC155 Espresso Machine
Delonghi EC 155 general help
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Feb 02, 2009 | DeLonghi EC155 Espresso Machine
New unit just won't work - keeps saying to insert brewer unit
These machines seem to respond to what their CS dept call "priming the pump." Turn on machine and after it has warmed up, turn the hot water valve or about 30-45 seconds. Shut it off and after a pause 30 seconds, repeat this process 2 additional times. Do the same 3 cycles in the steam mode. ( hit the steam button for frothing) Check openings  where coffee comes out with a small wire, ect., to make sure they are clear. It should work.
Mar 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
I beleive these are the instructions you were looking for.
If not the correct model, please post back and I'll do my best to help you further. I hope this helps.
Nov 29, 2007 | DeLonghi BAR 140 Espresso Machine
the filter has a little indent that must be placed correctly, if you put the filter in the holder and then rotate the filter you will feel it click into place when it is in the right position ( there is a gap for the indent at the front of the holder)
Oct 30, 2007 | DeLonghi BAR 140 Espresso Machine
Failing delonghi espresso machine ed140
check the filter holes. They might need to be cleaned with a needle.
Aug 27, 2007 | DeLonghi BAR 140 Espresso Machine
DeLonghi EC140 Espresso Machine Logo
900 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Ernest R
Ernest R
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
