Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Installing Bosch SHE44
I bought a floor sample SHE44 and I'm installing it. It came with apparently an extra water supply braided hose that is attached to the REAR of the machine. I want to use the existing copper pipe and connect to the front water connection. Do I have to do anything with the extra supply hose? Remove it? Plug it? Point it upwards?
    Sergeant:
  • 279 Answers
You shouldn't have to do anything, as the water supply line should have a one way valve in there somewhere. However, you might want to remove it, just so it doesn't get in the way, and you have it undamaged should you ever need it.
Posted on Sep 05, 2007
SOURCE:
How to lengthen the water supply hoses. There to short to reach sink.
Buy a flexible braided hose for mains pressure. They come in different lengths.
Fit one end to the water outlet tap and for the other end you will need a fitting you can attach the dishwasher hose to that any plumbing supply has. I don't think you can buy a flexible braided hose that will fit to your water supply tap on one end and then straight to the end of the dishwasher hose on the other. You will need the adapter between the 2 to hook the fittings up. Use plumbers tape on the fittings when installing them for a good water seal.
Or you can just get a plumber in who will fit everything up for you and will also probably use a flexible hose to plumb in the water supply.
Jan 04, 2016 | Dishwashers
After installing a stainlesssteel braided hose for my ice maker ( replaed a copper line) the ice cubes taste metalic. Is this normal?
No Its not normal, first of all did you flush the entire line and replace the filter at the same time? All of this is a factor. A stainless steel line is nothing more than a rubber hose wrapped in a steel mess, it very easy to move around and install. I think allow time for the water to settle and flush out the entire water system with a filter change should fix this issue.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 03, 2013 | GE 5 foot Braided Hose water line ice...
Bosch she43f15uc just stopped pumping water. Any ideas? it is only 18 months old.
My Bosch dishwasher had the same problem. After checking the over flow pan I removed the inlet hose to check water flow. There was none. I checked my cut off valve...open...I had water at the kitchen facet...scratch my head...I looked closer at the Bosch supplied braided water hose. It is directional (label indicating which end to hook to supply)....closer inspection reveals maybe there is a back flow valve in that side of the braided hose. Disconnect, blow air through...air passes freely...reconnect and bingo water flow at the dishwasher. In line back flow valve...can you imagine what a repair man would have charged for that?
Apr 04, 2012 | Dishwashers
Bosch SHU4006 UC/06 Dishwasher will not fill with water and timer does not advance. Voltage to Water Valve Solenoid does not toggle when timer knob is manually advanced through all cycles.
If you have power to water valve when it is supposed to fill yet doesn't the water valve is bad, as long as their is a good water supply to the valve. Sometimes espically if it has one of those flexible stainless steel braided hoses something in cabinet could have pinched it,
Good luck,i hope this helps
Gene
Aug 01, 2011 | Bosch SHU4006 Dishwasher
Need install guide for bosch dishwasher model smu 2042 uc Need to know if it suppose to hook up to cold or hot water?
Welcome to FixYa.
The dishwasher must be connected to an adequate hot water supply.
Adequate meaning a good strong rate of flow and pressure of hot water.
That should answer your question. Thank you for choosing FixYa.
Good luck.
Regards,
Macmarkus :)
Sep 04, 2010 | Bosch 24 in. SMU20 Built-in Dishwasher
Never installed a dishwasher. Want to give it a try. Ha a LG LDF6920ST.. Any advice?
For water supply, use a braided stainless steel flexible dishwasher supply hose with 3/8 compression ends on each side and a 3/8 male NPT x 3/8 compression elbow adapter. There is a tee with 3/8 female compression x 3/8 male compression x 3/8 male compression which can be used between the hot water shut off valve and the supply tube to the kitchen sink faucet to get your hot water with no significant plumbing work. Make sure the drain hose does not run straignt down back to the dishwasher. (put a loop up to make sure no dirty water tries to go back to the dishwasher.) If installing drain to a disposer drain port, make sure the knock out plug has been removed. It's also easiest if the floor under the dishwasher is at the same hight as the rest of the floor in the kitchen. Make sure wire nut connections are tight for electrical.
Dec 04, 2009 | LG LDF6920ST Stainless Steel 24 in....
Kenmore UltraWash Dishwasher is leaking from black hose...
No you will have disconnect the copper line. I would suggest that while you have it out that you replace the copper line with a braided stainless steel hose (also known as a dishwasher connector hose) If possible get a 60" or 72" hose so you can hook up the dishwasher when it is out and then push it back in with the water supply already hooked up.
Jul 31, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Bosch Classixx 1000 Express washing machine won't fill with water
cheak the filter witch is at the intake and if when it is going to fill does it buzz if dose that means the vale is working if not call a repaire man out hope this helps
Jan 22, 2009 | Bosch Classixx WVF 2402 Front Load...
Installing a bosch dishwasher SHE44C06UC
just clip it to the side.  I had the same questions after ours was installed wrong
Jul 31, 2008 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch NOT completing cycle NOR draining water
This may or may not be the issue: I have friends that bought a new dishwasher - I'm not certain, but I think it was a Bosch. They did have similar draining issues.
With their dishwasher, the installer did not follow directions properly. Yes, he'd "installed a million dishwashers", but was too self-confident to check the directions for something particular to this machine. There was something about the way one of the drain or supply hoses was supposed to loop around that was unique to installing this brand, and that ended up being the problem.
Make sure that your machine was installed properly in this regard, even if your installer says they know what they were doing. Call Bosch's customer service dept. if you have further questions.
Sep 11, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
141 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
