Question about Maytag MSD2454G Side by Side Refrigerator
Fridge not cool, freezer fridge temp
I have a Maytag MSD2454GRW side by side fridge. The fridge is room temp, freezer fridge temp. I have defrosted the ciols in teh back of the freezer with a hairdryer, unplugged it and let it set then plugged it back in. I also vacuumed the back fan and component area. Plugged it back in..it worked...for a few days. Now the ice has melted and the fridge is back to room temp, but I have a lot of frost/ice down the back of the panel in the freezer. What could the problem be??
    Novelist:
  • 87 Answers
The most likely fault is a problem with the defrost cycle. The most likely is the defrost heater which should be a solid bar which is located directly underneath the coil. If you are capable then you can generally unplug the connectors for the heater and check that you have a resistance across the ends if the heater is faulty it will be open circuit. If it is not open circuit then it could be the defrost sensor or defrost timer at fault. You can also generally tell if the heater is warped or cracked. Hope this is of some help.
Posted on Sep 06, 2007
SOURCE:
Fridge Maytag model msd2454GRW - Refrigerator not cooling, alot of moisture buildup in fridge. What is the symptoms of the defrost timer sticking on.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Maytag Refrigerators
Freezer is leeking inside. MSD2454GRW. 2003 Maytag.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 15, 2011 | Maytag MSD2454G Side by Side Refrigerator
The freezer is cold but i have the fridge at the coldest and it is at room temperature
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 04, 2010 | Maytag MSD2456G Side by Side Refrigerator
My kitchen aid refrigerator is not cooling like it use to, the freezer side is ice cold but the fridge side is almost at room temp, i have a feeling its the thingy in between the freezer and fridge at the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 09, 2010 | KitchenAid KSRS25IL Side by Side...
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so...
heatman101
Aug 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
Not cooling enough
I had the same problem and I discovered it was the defrost element that was shorted out which keeps the ice from building up located behind the back freezer wall.
Aug 09, 2009 | Refrigerators
Fridge side is not cooling, freezer side is fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 08, 2009 | Refrigerators
MSD2454GR Side by Side refrigerator- freezer side fine, refrigerator side will not cool below 50 degrees; lots of condensation
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 01, 2009 | Maytag MSD2454G Side by Side Refrigerator
Frige problem
This is almost a word for word common problem. On frost free fridge freezers of this type all cooling is generated through the freezer side and is merely forced into the fridge side through airflow. Therefore if you have a problem with the fridge you have a problem with the freezer section. The most likely cause is that the coil is frozen up. We would always suggest defrosting unit overnight in case it was simply a door left ajar being the cause of the fault. If the unit then pulls the fridge temp down and it was not the door ajar then you probably have a defrost problem (heater or defrost thermostat, or defrost timer). If it fails to pull the fridge temp down on restarting then it could be the fan or part of the defrost circuit or even possible the cooling circuit. The normal outcome after defrosting is that the temp will drop in the fridge due to air circulation improved, which will probably remain cool for 2-3 weeks until the coil becomes frozen again. On either result I would contact an engineer on the 2nd failure occurrs so that the engineer can establish the exact cause. Hope this helps.
Aug 13, 2007 | Maytag MZD2768G Side by Side Refrigerator
Maytag MSD2454G Side by Side Refrigerator Logo
293 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
