Emergency brake handle "sleeve" removal !!!
I own a 2007 Nissan Maxima and I would like to remove the emergency brake "sleeve" and reinstall it !!! The EB sleeve has a seam about 8" down from the front of the EB button ! Is this sleeve hard to remove and how much time should it take ? Thank you, Bob Ritter, 631-563-2833. e-mail : [email protected]
  • simon949 Sep 05, 2007
    I saw no experts that could answer the automobile question that I have or I would use the Premium Assistance Plan !!!
    From seeing your list of experts, it doesn't look like your going to be able to answer my auto. question !!!
Whoa!!!!! lay off the punctuation!!!!!
Posted on Mar 10, 2008
SOURCE:
My 1992 Maxima brake lights will not go off
Most likely the foot brake switch mechanism is faulty and needs to be replaced.
Nov 25, 2015 | 1992 Nissan Maxima
Tip
Removing rear rotors
On the rear wheels, the inside of the rotors act as a drum for the emergency brake shoes. You must loosen the emergency brake so that the shoes back away from the inside walls of the rotor. Loosen the emergency brake, left and right side, by loosening both nuts at the emergency brake handle. Further, the emergency brake's internal adjusting nuts are accessible through the lug holes in the hub. Then remove the rear rotors
on May 19, 2008 | 1987 BMW 5 Series
Brake light on dash evening when the emergency brake is not on. what could cause this? also does thie vehicle have brake shoe or pads for the emergency brake.
Typically if your brake light is on and there is nothing going on with the Ebrake, when the pads start to wear down, that can drop the fluid level and set off that light. You may need to just replace pads and possibly top off fluid. Hope this helps.
Dec 28, 2010 | 2004 Nissan Maxima
Replacing rear brakes nissan maxima 2000 turning caliper piston With GM cars, the caliper piston can be turned with needle nose pliers. I have removed the emergency brake cable and still cannot rotate the...
by a caliper wind back kit first with both anti clockwise motion and clock wise motion. have ya tried that. you also need to apply pressure on the piston at the same time as turning
May 16, 2010 | 2000 Nissan Maxima
Dash brake light came on. Emergency brake is not
spray the break pads and calipers to make sure they are not ingaged
Jan 11, 2010 | 2000 Nissan Maxima
The caliper operates the brake pads and emergency
No its the same as normal rear caliper removal.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Dec 07, 2009 | 1996 Nissan Maxima
How do i remove the rear brake drum on a 04 ford transit
If you can't get emergency backed off to allow for movement, then you'll have to get small pointed object (screwdriver or whatever) in adjustment hole to lift lever holding adjuster wheel, then back off adjuster wheel at same time until free. If it's emergency cables seized at backing plate area, try spraying where cable goes into sleeve with penetrating spray, and rap sleeves of cables going into backing plate with a stick, or screwdriver handle and it may help them retract enough to loosen up shoes in drum. Good Luck.
Jun 20, 2009 | 2002 Ford E350
MY EMERGENCY BRAKE IS STUCK WHEN I DRIVE (STD TRAN).THE HANDLE TO PULL THE BRAKE ON PULLS OUT AND BACK IN EASY AND DOESNT LET ME RELEASE THE BRAKE. ANY WAY TO FIX THIS?
jack up the truck, remove back brake drums and loosen emergency brake hardware next to calipers.  Reassemble and lubricate all cables.
That's it in a nut shell.
Apr 01, 2009 | 1991 Nissan Pickup
Emergency brake repair
sounds like you need an emergency brake adjustment. Around 35 dollars. I'm sure while it's being adjusted the brtakes will also be inspected. Rear brakes might also be low.
Mar 31, 2009 | 1992 Nissan NX
Emergency brake stuck is there a releace
have to raise car up SAFLY use visegrips to pinch cable about 2 inch from where it goes into sleeve at wheels then knock it back in with hammer BE SURE to release at handle first
Jan 09, 2009 | 1985 Pontiac Fiero
Computers & Internet Logo
255 people viewed this question
Ekse
Alun Cox
