Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Turning on problem with Panasonic Viva PT-43LC14
I just purchased this TV from a frined about 4 months ago for a really good price. He purchased this unit about a year ago brand new and never had any problems with it. The unit was working perfect ever since i brought it from him and all of a sudden last week Tuesday I hit the power button on the remote and the TV turned on after about 10 to 15 seconds, which is normal but after it turned on it all of a sudden turned off. Now when ever I hit the power button the power light flashes on the TV which it normally did before it powered on but after 10 to 15 seconds the screen still stays blank and you can hear a like light rattling sound coming from the TV not sure what that is. I am not sure if a bulb blew or what is wrong with it. Any help would be greatly appreciated. Thank you.
    Problem Solver:
  • 8 Answers
Re: turning on problem with Panasonic Viva PT-43LC14
Sounds as you have a bad ballest. The ballest is the power supply that turns your lamp on. You can check your lamp by removing it and it should be clear and no broken pieces of glass. With the lamp removed install the cover and turn it on you should hear no noise and when the power light turns red you should see a LAMP red led blink every 5 seconds. If no noise then the lamp is bad. If you do hear noise you have a bad ballist. Hope this helps. Frank
Posted on Oct 09, 2007
0 characters
3 Points
I hear a noise in the back of my Panasonic PT-43LC14
Feb 03, 2014 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT43LC14 Manual Download
Download Panasonic PT-43LC14 HDTV Manual
Models: PT-43LC14 / PT-50LC14 / PT-60LC14
Have you misplaced your Panasonic PT-43LC14 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Panasonic PT-43LC14 HDTV Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on Apr 30, 2010 | Panasonic PT-43LC14 43" Rear Projection...
My Panasonic PT-43LC14 HDTV doen't have a remote. How can I manually set the TV settings?
purchase a universal remote from an electronic supplier, IE Walmart and as per the instructions sent with you new remote, program it for your TV, you will regain most if not all the features and functions your original remote.
Jan 09, 2012 | Projection Televisions
Reset lamp timer panasonic tv
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down SPLIT PLAY button on the remote until a message appears on the screen that the lamp timer has been reset.
Good luck
Note: I got it from here:
Dec 13, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic pt-43lc14 won't turn on
Try checking your lamp door. I have seen a few of these that you need to really wrench that screw down. Let us know.
Mar 22, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic projection lcd pt-44lcx65 pink wavy lines
The problem is the computer in the TV is set to hold data for 2500 "On/Offs" Once you turn the TV on and off 2500 times, the dots start to appear as the computer cannot store anymore date. Call Panasonic, they will send a tech to your house for free and reset the computer and update it at the same time from 2500 to 1 million on/offs so it wont happen again. It takes maybe 10 mins to complete.
Hope this helps.
Mar 25, 2009 | Panasonic PT-43LC14 43" Rear Projection...
I have a panasonic rear projection lcd, it has a yellow tint around center of screen. Help
My PT-43LC14 has a yellow tint on 3/4 of the bottom to top. the top 1/4 seems normal. I removed the bulb assembly and it looks OK. Any ideas. Is there anything I can doe myself. and if so what is the p/n I can buy?
Mar 18, 2009 | Panasonic PT-43LC14 43" Rear Projection...
TV turns off after being on for just
I have the same problem and I believe the new problem is the cooling fan is not working properly and the unit is shutting down to protect itself from the heat.
Dec 16, 2008 | Panasonic PT-43LC14 43" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
SPLIT for Models:
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
2,000 people viewed this question
Top Panasonic Projection Televisions Experts
Jaime Hernandez
Josh Whitehead
Josh Whitehead
Are you a Panasonic Projection Television Expert? Answer questions, earn points and help others
