Question about Aluratek 3.5" USB2.0 320GB External USB 2.0 Hard Drive
Can't transfer info between computer and external hard drive
First time user, so no idea what to do. When I try to drop/transfer anything to my aluratek hard drive, it says 'the item could not be moved because "ALURATEK" cannot be modified.' What's the deal? What can I do? Thanks.
4 Suggested Answers
  • 44 Answers
SOURCE: Aluratek 500 GB Hard Drive Troubleshooting
I take it from what your saying, this is a brand new hard drive.. if so it simply means that before you can use the drive.. simply click on start, the right click on my computer and go to manage. next, click on storag and then disk management local... right click on the new drive and go to format!
hope you manage okay!
Posted on Dec 26, 2007
SOURCE: external hard drive making alarm noise and will not load
A drive making noise suggests that something physical has gone wrong.  If something happened so that the OS simply can't access your data and there not too much physical damage to the disk, try one of those recovery programs, but one that doesn't attempt to fix the disk, only access the data
Posted on May 12, 2008
  • 828 Answers
SOURCE: My PC is not recognizing Aluratek AHDUB250 External hard drive
did you check it connect properly on USB? how about to try it to run in another PC maybe it works there. If not then you should buy a new one.
Posted on Jul 21, 2009
SOURCE: Aluratek went away and won't show up
I have the same problem with my Aluratek AHDDS100F Sata to usb 2.0 docking unit. It will only work now if I connect it via usb 1.1. I am using a Iomega usb 2.0 pci card.
Posted on Mar 14, 2010
0 characters
1 Points
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software:
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
How to transfer my life studio from one computer to another
Connect the external hard drive to the host computer.
This connection is most commonly made with a USB-style connector.
However, eSATA connectors are becoming more prevalent in the general computing market.
Plug the external hard drive into an electrical power source.
Navigate to the external hard drive listing under the "My Computer" window.
This is opened by double-clicking the "Computer" or "My Computer" desktop icon.
Double-click the external hard drive drive icon listing and navigate to the files to be copied using the provided navigation window.
Right-click the files to be transferred and select the "Copy" heading from the context menu.
Navigate to the destination folder on the host computers hard drive using the same navigation window.
Right-click within the folder and select the "Paste" option.
This begins the process of transferring the files to the computers hard drive.
This process takes several minutes to several hours, depending on the size of the files and the speeds of the hard drives.
A progress bar will appear to keep the user informed of the process completion status.
hope this helps
Jul 16, 2012 | Hitachi LifeStudio HLSDBUB10001BBB 1 TB...
1st time using and confused trying to back up old laptop info to transfer overe to new laptop, i plugged in but didnt do anything
you will need to run files and settings transfer wizard in windows to transfer all the data to your external hard drive, it wont just back it up for you automatically
Mar 10, 2011 | Iomega eGo Portable Hard drive 500 GB ...
How do I transfer photos to the external hard drive
once the external hard drive is plugged in to the computer check under my computer is detected if it does
open the folder where or you can right click the folder or file you want to transfer then select the name of your external hard drive.
you can also use the software that came with your external hard drive but its much easier to drag and drop the files.
hope this help
Sep 07, 2010 | Western Digital Elements powered by WD 320...
I'm trying to sync my files from my old computer
no you can what you have to use is files and setting transfer wizard in windows xp you can start the Files and Settings Transfer Wizard by clicking Start on the computer running Windows XP, pointing to All Programs, Accessories, System Tools, and then clickingFiles and Settings Transfer Wizard. (If both computers are running XP, you can start with either one.)
just select "i want create wizard disk in following drive " and select you external disk drive tha will do the trick...
Apr 11, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
I've connected my 320gb prestige usb 2.0 portable hard drive to my computer, so now how do i transfer my file on to it?
Hello my friend,If you are a Windows user, your external hard drive will show up on the My Computer screen just like any other hard drive.Drag and drop (or copy & paste) the files you wish to back up on your external hard drive.That`s it:)
Feb 08, 2010 | Prestige Portable 320gb Usb 20 IOMEGA ...
How do I download files and pictures to an external hard drive and transfer info to another computer
If your external drive is connected to your computer, you can simply 'send to' or copy and paste.
Click on 'My Computer' and you will see the list of drives. You can then copy the files from their current folder and then paste to the external drive.
You can even 'drag and drop' the files!
Easy to do!!
Oct 05, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My 2nd hard drive (samsung) which stores my music and games suddenly vanished from my list of drives in my computer. it is still listed in device manager which indicates that the drive is working ok. how...
do you have 2 hard drives or a partitioned hard drive? anyhow go to my computer check and see if the drive is listed. If not you may have to reinstall it. If the drive has become defective there are readers that can transfer your info. You also can take it to Geek Squad or other service and they can transfer your info to a new external drive ( i suggest an external TB drive you can get the for $150 and they are well worth it) for music purposes and archiving. Portability alone makes it a great choice.
Apr 28, 2009 | Samsung SpinPoint M60 HM120JI 120 GB SATA...
Transferring data from an external hard drive
Best solution is to make an image of the PC and then use that image to transfer it back. Norton Ghost is a good application for that, but there are more.
Mar 02, 2009 | Western Digital Hard Drives
Aluratek 3.5" USB2.0 320GB External USB 2.0 Hard Drive Logo
Top Aluratek Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you an Aluratek Hard Drive Expert? Answer questions, earn points and help others
