Back to:
Tags:
Sharp 13H-M60 TV
Help fix 13 '' sharp tv
By Beresford - usenet poster
Hi I have this cheap newer all black plastic sharp tv model 13H-M60
it plays good all day then just shuts off
i turn it back on and it makes a white screen full of wavey lines . the
minute i push the channel button the set turns off
if i leave it aloan it will stay on with that white / wavey screen all
day .
i have heard this may be the main micro processor chip
is there a common ''fix'' for this cheapy tv problem ?
or do we just throw it away ?
ken
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 08, 2005
FixYa! (100)
LiZzIe
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This may be from some failing capacitors in the power supply.  Because
of the lack of filtering and stabilty in the power supply, the set may
start acting up.
Someone that is properly equiped and have good tech skills can fix
this for you.
Jerry Greenberg
Email:              jerry @hotmail.com
Home Page:   http://www.zoom-one.com
Components:  http://www.zoom-one.com/electr on.htm
Navigation:      http://www.zoom-one.com/naviga ti.htm
Sci/Inst:            http://www.zoom-one.com/actel. htm
Personal:         http://www.total.net/~jerryg
Electronic Components, And Navigation Compasses
============ Message Separator ===============
the
day .
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on help fix 13 '' sharp tv:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
message on tv says speaker off
i'm completely lost as to how to connect up the above...
When I attempt to turn it on, it seem to go into a...
samsung tv When I turn it on it goes to menu with double...
Sharp 13H-M60 TV
The sound went out on my television. I did not have a...
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
