Poulan Genuine  Weedeater Part # 36006-128 Logo
A
Anonymous Posted on Aug 15, 2013
Weed eater will not start. when it does it will not cut grass. Just knocks grass down. Shaft does not turn fast enough. Idles instead of reving up. Can reach down and grab string and it stops.
1 Related Answer
Anonymous
  • 41 Answers
  • Posted on May 19, 2009
SOURCE: Weed eater GTI 17 won't run on high speed
A couple of things may work...
Make sure you have the correct Oil / Fuel mixture, if it is incorrect the motor may have problems running.
Also take off the bottom where the cord is wound up, make sure there hasn't been any grass get wound up inside it, this will cause it to stall out on high RPM.
Weed eater turns but will not cut the grass
Start with carb adjustment. Turn out the low and high adjusting needles 1 full turn, then adjust the choke.
I have a craft man weed Eater 27cc. When I start
Check the motor hasn't moved up the shaft and separated the inner drive cable from the spindle.
Sep 03, 2014 • Garden
I have weed eater/poulan 22" push lawn mower. It
Hi goldengear...
Make sure you have installed the blade on the right way, if it is installed upside down then it will "beat" the grass instead of cutting it and make a terrible cut, also make sure the blade is good and sharp.
The rough running may be due to trash in your carburetor, I would advise to clean your carburetor and also check you fuel tank for trash, water,etc. if there is any trash,water,etc in there then you need to also clean the fuel tank.
Do one more thing and check/clean/replace your fuel filter if you have one.
Please take time to rate me
Head will no turn at all can't cut any grass this on my troy bilt weed eater
This sounds like a problem with the drive shaft (s) or the gear head ...partial disassembly of unit to verirfy would be required.
May 26, 2010 • Troy Garden
1helpful
String trimmer cutting attachment doesn't turn fast enough
Take the shaft off at the motor,see if any thing is worn there.Also,take head off of end of weed eater,check for grass or any build up in there.
My Ryobi weed eater loses power at working speed after 5 minutes.
you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Top Poulan Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Poulan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
