Runs doesn't cool
1. it was making some loud noises and then stopped. now it blows hot air but when the thermastate is turned up to cool it tries to turn on but can't. so all i get is hot air. 2. on second air unit, there's water not ice just cold water built up on the inside fins behind the filter and it is constitently cutting on and off when on power saver. it does cool somewhat.
Where is the air filter for the ruud ( #uak037jaz) air conditioner
Posted on Aug 29, 2009
    Novelist:
  • 75 Answers
Hi, Give the first unit about 15 minuets and try it again. The pressures have to equalize it the system before it will restart each time the compressor kicks off. The second one sounds like its doing what it needs to do. There should be water on the fins but no ice. Hope this helps. kstfas
Posted on Sep 06, 2007
The unit is blowing hot air it will blow cool and then make a loud noise and start blowing heat.
Sounds like your ac is kicking out on high limit or internal overload. Several factors come in to play. Outdoor coil fins blocked or bent.
Check temp of compressor.
Aug 29, 2014 | Heating & Cooling
No heat in F-150 could it be thermastate
-No. not the thermostat. Here there are couple thing that cause the heater not blow hot when you need hot.
1. Water line to the heater core is plug, or the control valve is not open due to broken linkage (Cable).
2. The vent butterfly stuck in cold air position.
Good luck
Mai
Feb 04, 2014 | Maisto 2004 Ford F150 Fx4 Pickup Truck...
My 1999 Chevy Malibu runs hot? It started when it overheated. We changed the thermostat, then water pump, then temp sensor gauge and the temp gauge goes high but only when the heater stops blowing hot...
Air pockets will make the guage do that, and also cause your heat to come and go. Also, a poor radiator, as in rotting, or plugged up, will cause high temperature issues.
Sep 20, 2011 | 1999 Chevrolet Malibu
The air conditioner stopped blowing air. It is still too hot for it to have shut off automatically, When I power it down & turn it back on it makes a noise but won't start blowing the cool air. The...
Your going ot have to shut it down and let it deice. remove the filter and replace it or wash it out . this might take a few hours so leave the indoor fan on it will speed thing up a bit. also set the temp to mid range and close all unused rooms off it has to cycle a bit but really my money is a dirty filter and ice.
Jul 19, 2011 | Heating & Cooling
My dads Friedrich floating air wall unit won't stop making a loud noise even though it is powered off. I tried to power it off but it will not stop making this noise, it has never done this and it always...
It is possible it is the noise of refrigerant balancing when the compressor shuts off. Does the noise ever stop? Have you turned breaker off??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 14, 2017 | Friedrich M18CF Split System Air...
MAKES A LOUD NOISE AND BLOW HOT AIR AFTER BEING ON FOR A 5MIN
You can try to turn the power off and then on again at the disconnect for the outdoor unit...
However the problem is likely more complicated then that...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 25, 2010 | Ruud UBHC Air Conditioner
AC cools then blows hot air, tempature needle goes up & down
Sounds like the thermostat is trying to stick,and is causing the engine to over heat,therefore condenser is not cooling the freon down enough to cool.Have the thermostat changed and the cooling system bled out,this is most likely the cause.
Aug 29, 2009 | 2005 Lincoln LS
Outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Jun 15, 2008 | Weather King 10AJA4201AH Air Conditioner
Central ac blowing hot air outside fan not moving but making a noise
This is nothing but an either or -or ! First, make the thermostat calls for cool, there are suppose to be 2- noise outside, the fan motor and the compressor (and if a old system,a humming noise which is the contactor coil which picks up the main 240-volts).. hurry up and take a stick or something and turn the fan blades, if it picks up speed and run, then its the capicator. If not then the fan motor is bad.! (BOTTOM LINE)!
Jun 09, 2008 | Heating & Cooling
LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
Heating & Cooling Logo
256 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
