Question about Sony Handycam DCR-TRV19 Mini DV Digital Camcorder
My trv-19 cannot record video
When I switch to camera function, the monitor screen and the view finder are both black, when I press the record button, I can record audio but not video. Can you tell me what is the problem? Thanks
  • specialk71 Mar 27, 2008
    I have the same exact problem did this help
  • carmaysully Aug 05, 2008
    exact same problem. The screen is black and when i try to record, it only records audio and only shows audio in the lcd screen. When I play back a previously recorded tape it plays just fine on the screen though.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
If you can play back ok but cannot record then your CCD sensor is faulty: replace CCD block.
Posted on Sep 06, 2007
Epl2 black screen
I can't think of much. Perhaps you pressed the button, to change the view from monitor display, to extra view finder display?
Try pressing that again.
I don't thin it has anything to do with the brightness settings of the screen.
Jul 22, 2014 | Olympus PEN EPL2 Digital Camera
Off lens,view finder is not workink
The view finder is the little window on the top left of the camera. If you want to use the display as a view finder, you have to press the button with the camera logo. It is called the life view mode. you use the same button to switch off the display. Be aware using the display, will drain the batteries quicker. Somewhat faster then with modern cameras.
see page 19 of the manual.
Dec 02, 2013 | HP Photosmart M307 Digital Camera
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
I Have a SONY Handy cam model CCD TRV 408 E. The problem I am facing is that I cannot see any thing from the view finder when in the camera mode. However when the LCD screen is opened I can see normally...
Fixya does not offer a repair service for any equipment. Have you checked that there is not a menu setting that you have overlooked? The manual may be helpful in this.
Aug 04, 2017 | Sony Handycam CCD-TRV408E Camcorder
Sony DCR-HC18E, the backlight on the LCD screen will not light up, it does record but you can't see what you are recording and can hardly see the on screen function / menus. Pressing the backlit buttons...
If you close lcd screen in its position, do you see image in eye piece (view finder) ?
If yes, then replace flexible ribbon connecting wire between camera board and lcd board to get picture in lcd screen.
Let me know if you need part number of flexible ribbon wire.
Thanks.
Apr 21, 2010 | Sony DCR-HC18E Mini DV Digital Camcorder
How do I switch from the view finder to the lcd monitor on my canon rebel xsi
You must be in P, Tv, Av, M, or the A-DEP modes.
Enable Live View in the camera’s Menu.
On the second set-up menu screen go to
“Live View function settings” then "Live View Shoot"-> enable.
After this all you need to do is press the Set button.
Mar 10, 2010 | Canon EOS Rebel XSi Digital Camera
When I turn on the camera, nothing happens and the screen/view finder is blank. i checked the standby switch its off. when i press record it will record but on the tape it is just a black screen? any ideas...
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Dec 03, 2009 | Canon GL1 Mini DV Digital Camcorder
Nothing appears in view finder or on screen when recording
I HAD THIS PROBLEM ERROR CODE C31 : 22 WOULD COME UP AND TRV 118 CAM WOULD NOT WORK. I TRIED EVERYTHING TILL ONE DAY I BANGED IT ON A CARPETED FLOOR ON THE BOTTOM OF THE CAMCORDER 5 TIMES QUITE HARD. THEN THE CAM WORKED JUST FINE! MY CAM HADN'T WORKED FOR OVER 7 MONTHS. NOW I HAVE IT BACK. HOPE THIS HELPS SOMEONE.
Jun 18, 2008 | Video Cameras
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
Nikon coolpix 5700
at the back of the camera next to the view finder (bottom right hand corner) is a button and icon marked SEL. pressing this button toggles the lens image from the view finder to the lcd screen and back again. IF neither view is available then I suspect your camera needs some TLC at a repair shop. hope this helps.
Jun 26, 2007 | Nikon Coolpix 5700 Digital Camera
Sony Handycam DCR-TRV19 Mini DV Digital Camcorder Logo
227 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
