Question about Whirlpool GS6NBEXRS Side by Side Refrigerator
Warm Fridge side
Freezer icing up, fridge warm
    Novelist:
  • 87 Answers
Defrost the fridge freezer overnight. Restart unit. If it starts working you have either had a door ajar or a defrost problem. If it fails to cool down at all then you may still have a defrost problem or a evap fan motor faulty. Most likely outcome is that the unit will work once defrosted for approx three weeks after which the freezer will freeze back up. Most likely cause will be the defrost heaters. Any good tech should be able to help on second failure. Hope this helps.
Posted on Sep 06, 2007
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
:o).
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
Defrost works fine but ice builds up in return air channel and fridge gets warm. model 106.55622500. Fan Ok, no ice on coil after defrost defrost timer ok. settings on middle of range after 3 weeks ice...
Hi!!
You may have the temp. set TOO HIGH for the freezer, set it in #2, leave the fridge setting in the mid range for now. Check after 24hrs. and adjust as necessary.
Good Luck!!
Mar 20, 2010 | GALAXY Microsystems 25.4 cu. ft....
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
VENT THE MIDDLE OF THE FRIDGE IS ICED UP SOLID. THE FREEZER WORKING FINE BUT THE FRIDGE IS GETTING WARM.
first thing to try is to turn of the fridge and let all the ice thaw out, could be the vent that moves air to the refrig portion from the freezer is blocked by ice
Apr 06, 2009 | Maytag MZD2669K Side by Side Refrigerator
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Whirlpool GS6NBEXRS Side by Side Refrigerator Logo
185 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
