Question about Lowrance Iway 500c GPS Receiver
Lowrance 500c touchscreen
The touchscreen has stopped responding to my touch - it boots up ok but will not allow me to control it through the touchscreen
  • 11 more comments
  • Anonymous Dec 02, 2007
    Touch screen does'nt operate at all.I have not tried to fix the problem until today. please contact me if you know what i can do to resolve this issue
  • Anonymous Feb 08, 2008
    I too,having a problem of the screen not responding to the touch.. Lowrance wants me to send in for update to the tune of $150.00. I already paid too much for this thing and tell all our RV friends and anyone else who will listen, to think twice before buying Lowrance.
  • Anonymous Apr 09, 2008
    Touch screen is frozen, and soft reset does not work. Unable to perform hard reset as the touch screen is frozen.
    Support is asking for $149+shipping as it is out of warranty.
    My best solution:
    I got a brand new Magellan 4200 for $199
  • Anonymous Apr 17, 2008
    During a recent trip we booted up the i 500 C. After about 30 minutes it began to shut off without a prompt. After reboot it failed to respond to the touch screen icons. Can some one explain what is causing the problem and what is the solution that would justify its repair.
    I removed it from my truck thinking that the software needed update. Reading the instructions I found that I had the latest software update. Is this a software problem or a hardware problem.
    If this is a hardware problem then I believe that Lowrance should repair it with out cost.
    HMK, California
    I was on my job using the 500C when the touch screen stopped functioning properly, it would simply freeze up thus rendering it useless. The function buttons on the side would work, but it would not allow me access to directions, I could not get passed the "Warning from operations while driving Screen." This was such an inconvience as I had 5 other stops which I could not complete. This unit is not quite 2 years old and I paid $599.00 with a $100.00 Rebate, but $499.00 is still too much for this unit to malfuntion in such a short period of time. I have installed the latest update. If any one knows the fix for this problem please post.
  • skungagook Apr 22, 2008
    same problem others have described touchscreen will not respond to my touch , i have done the screen calibration about everytime i use it and gotten all the software update and it still freezes right when i need it the most.
  • BobGrif Apr 25, 2008
    Yep... My touch screen stopped working after 3 years of service. All other functions work, but still a useless boat anchor now. Since Lowrance is not a mainstream GPS player, I guess I'll buy a TomTom or Garmen and go anchor my boat with the Lowrance. - Bob Griffith -
  • SOLin ME May 04, 2008
    yes, after now 1 1/2 yrs of ownership, I TOO have lost my touchscreen ability. I am very disappointed...I thought IWAY offered the best quality when shopping around!
  • Hoff man Jun 28, 2008
    I am having the same problem with my touch screen. I need to wait about 30 minutes for the unit to warm up until the screen will respond. Right now, it is summer in Green Bay, WI where I live- I would imagine this unit will be completely useless in winter. I would ever buy another Lowrance. They should be embarrased to have this product on the market. I am extremely disappointed!
  • Anonymous Jul 30, 2008
    My 500c went out on us on the way back from TX. Turned it off to go in to eat and when we came back out, the touch screen did not work. Totally unusable all the way home.
    Downloaded the Version 1.8 again and thought it might help to install that again. After the lengthy loading to the 500c and then the reboot of the 500c it still wound up with the same problem.
    It can bring up the screen and I can move the map around from the US, to the Atlantic Ocean, Greenland, Finland, Russia, Alaska, the Canadian north country. A lot of good that is.
    Lowrance only has a replacement program for the 500c which is send yours back and they will send you a 600c. But, how long would that last? And to pay $350 for the 600c. I'm not much of a gambling man so I guess I'll just take it apart and see if I can find anything that perhaps got shifted in the heat.
    Sorry situation.
  • JoeM-NJ Aug 09, 2008
    I was having the exact same problem and contacted Lowrance to complain, especially after seeing the posts here. They sent me the following process to perform a hard reset and my problem was solved and the unit is working perfectly again. Good Luck!
    To perform a Hard Reset of the unit (will delete waypoints and address book)
    Turn the unit off, press and hold the Speak/Volume button and then press and hold the Power/Light button. Hold both buttons down until the unit powers up and you get the Testing 123 screen. Release the 2 buttons and you will see a button on the screen that says Hard Reset, press it and the unit will warn that this will delete all user data (address book). The unit will shut off, turn it back on and the unit is reset.
    To adjust the screen calibration:
    With the unit on, Press Menu twice select the System Setup button, then select the Screen Setup button. Select the Calibrate Screen button and then follow the directions that are displayed on the screen.
  • Anonymous Apr 02, 2009
    Touch screen does not work; however when I turn unit iff/on, he first time I touch the screen, I get the "beep" but no reaction. I tried Joes hard reset and got that screen to come up, but again no reaction other than the beep. HELP11111111
  • FujiTech May 12, 2009
    I have all of the above problems as well. With the orientation, and the touchscreen not working until it warms up. I have almost thrown this thing onto the highway many times if it werent for the MP3's and photos I have on it. Tonight I finally bought a #8 Torx and opened this POS. I looks like its a refurb or someone was sleeping on the job when making it. My 3 year old could have soldered the contacts better than they did. I dont want to do a hard reset to try to fix the screen because it works after the unit is hot so it couldnt be a firmware issue. If I could find a new screen I could replace it myself. My iWay500C also has always taken about 5 minutes to aquire sats. Buy a Garmin if you want a GPS.
My iway 500c kinda had the same problem. At first while driving, the screen would go from 3d to always north to always up and be switching screens 3 to 4 times a second. It would finally go back to normal. After about a month of this the touch screen would work intermittently. It finally quit working completely on a trip to Texas. When I got home I called Lowrance and the said they would replace it for $350. I already spent over $600 for it. I took the thing apart and found the grounding screw to the touch screen was really loose. I tightened it and now its working again for now. I am not happy with Lowrance support.
Clane
Posted on Oct 11, 2008
Solution: Go to main menu>screen setup>calibrate screen and recalibrate. Also, can do a hard reset. Info on Lowrance site.
Thx, Ralf
Posted on Jun 15, 2008
I have the same problem essentially. The only thing I can do is pan left and right in map mode. I can't access any of the buttons that appear onscreen as the touch screens calibration (or something) seems wacked out, the cursor seems to be buried in the bottom edge of the screen as I can just barely see the top of it. The only time the unit functions even remotely normal is if its *VERY* hot. Almost too hot to touch. Anyone have a solution?
Posted on Apr 25, 2008
I'm having the same problem. Every time I get the box out and get ready to send it in it starts working again. Seems like mine is touchy in the mornings. Once it heats up it starts working. I paid way too much for this to be having problems like this.
Posted on Sep 17, 2007
My touch screen is all wonky its not responding to anything I'm trying to do with it and its doing things that I'm not doing it's basically made my phone useless at this point
Tf810c Touch screen wont work ' TabletPCReview.com - Tablet PC ...
forum.tabletpcreview.com > Forums > Windows Tablet PCs > Asus
Feb 24, 2013 - 10 posts - ‎4 authors
If it's greyed out, there is no data to reset, and it's not that causing the issue. ... wentall wonky, swipe for charms wont work, can select anything ... I tried the hard reset and low and behold my touchscreen started working again.
Nexus 7 (2013) erratic touchscreen & keyboard - Google Product Forums
productforums.google.com/d/topic/nexus/W0Hfkq8hf-c
GoogleJul 30, 2013 - I've used some touchscreen test apps and "ghost" touches would ... Myoriginal Nexus 7 (2012) didn't do this, nor did my Gnex or any of ... If it's software, I don't mind hanging onto it until a fix is released. ...... I can't believe no one has saidanything about the touchscreen not responding at all to touches I've ...
XPS 9530 touch screen stops responding (how to fix) - General ...
en.community.dell.com/support-forums/laptop/f/3518/t/19534511
Dell
Dec 1, 2013 - 15 posts - ‎7 authors
Dec 16, 2015 | Cell Phones
Bernina 165 touchscreen not working
It sounds like you may have two problems - one is easy, but without the other, its hard !!! If the touchscreen isn't working, it may simply be mis-calibrated and cant be accessed. To recalibrate the touchscreen from scratch, switch the machine on whilst, at the same time, pressing both of the two needle position buttons - the calibration screen should then come up and you should touch the screen where the dots are shown to recalibrate it. If, pressing the dots does not do anything, the probability is that your touch overlay or main control board is faulty, in which case you will need to take it to your Bernina agent. If you manage to re-calibrate the touchscreen OK, switch the machine off and back on again and if the display is still very grey but readable, you can adjust the contrast of the display by pressing the button with an arrow facing right, inside a box - this will take you to the user adjustment menu. Touch the display button that has a symbol with three vertical bars of different shades of grey and this will take you to a display that allows the brightness and contrast to be adjusted - touch the up or down buttons to get the best display contrast and once this is done, you should be all working again. Good Luck
Jul 02, 2012 | Sewing Machines
My Garnin Nuvi 760 has stopped responding to touch screen. It starts and eventualy opens a map but nothing I touch on the screen will respond.
The problem is probably with touchscreen (a thin film on screen)
You can try order a replacement touchscreen on ebay and replace it yourself
Tip: order a couple of them, they are cheap but extremely fragile
May 19, 2011 | Garmin Nuvi 760 Car GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Screen works but dosent respond to any touching?
Check that the "touch screen lock" is not engaged. To avoid accidental activation of the touchscreen, many models use some kind of "security" so that after a fixed time, the touchscreen will stop responding unless you (e.g.) click an unlock button. Verify this on the user manual.
Nov 05, 2009 | Samsung Instinct Cell Phone
Touchscreen not responding
Try to find how to calibrate the touch screen in the users manual.
May 29, 2009 | Garmin nuvi 250W GPS Receiver
Fujitsu p1120 touchscreen not working
Before you open up your computer, try downloading the touchscreen drivers from Fujitsu's website and re-installing them. Sometimes they just get flaky.
Mar 19, 2008 | Fujitsu LifeBook P1120 Tablet PC
Screen Calibration
I'm a french customer with a Marantz RC5400 wich has a screen LCD broken but the touchscreen is OK
I don't have the fix for your problem but I'm searching for a screen replacement at low cost...
If you always have your Marantz with the touchscreen problem, I'm interested for a deal
Thanks
Dec 06, 2007 | Marantz RC5400 LCD Touchscreen Remote...
Touchscreen malfunction
Hello Dean, and good evening. I understand the issue you are having and I'm here to help. From the way you said it stopped responding, it sounds like it could have possible froze, or something is internally wrong with it. If it didn't freeze I would contact Nintendo about this problem, and possibly get a refund, or mail it in and receive a new one. Hope this helped! Have a great day!
Regards, Drake
Nov 29, 2007 | Nintendo DS Lite Console
Lowrance Iway 500c GPS Receiver Logo
975 people viewed this question
Top Lowrance GPS Experts
Jay Plesset
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
