Question about Refrigerators
Frigidaire refrigerator/freezer freezer defrosts daily water from condensor drains out onto the bottom of the unit then onto the floor.!
  • 2 more comments
  • mk1126 Sep 07, 2007
    the freezer half defrosts, water drains down - looks like there could be drain hole right underneath the coils but the water isnt draining into that! (should there be one there?) - then, runs down onto the bottom of freezer, most freezes there, forms an ice sheet, then more defrost cycles occur and water starts running over the ice under the door and onto kitchen floor.
    yes,freezes, defrosts, freezes. I saw another guy posted an identical problem yesterday also with a GE side by side.
    hello...........
    where is the water supposed to drain into when it does defrost though? it is not; thats the problem.
    will look at that
    Sergeant:
  • 279 Answers
You say defrosts daily... by that do you mean it freezes, then defrosts, then freezes again... in a cycle? Or do you mean it's just constantly leaking? Either way, I should be able to help, but I need to know more specifics first.
Posted on Sep 06, 2007
  • John Goodman Sep 07, 2007
    It sounds like your compressor is overheating. When it gets too hot, it shuts down, and the freezer thaws out... then once it cools down enough, it starts up again and refreezes everything.
    Check to make sure the area behind and under your refrigerator is clear. You may want to clean under the refrigerator to allow for clear airflow - that's the most common cause of something like this.
    It sounds like your defrost drain is clogged. It'll require some close examination to find where the clog is and clear it - this is more like plumbing than refrigerator repair at this point.
    I suggest you look at this site. I could reiterate what is there, but I wouldn't be as clear as they are. There is also a video showing how to fix the problem here.
    http://www.ehow.com/how_112132_fix-leaki...
    Master:
    Sergeant:
  • 461 Answers
Bit confuse with your problem.. are you having a defrost issue or leaking issue? If defrost issue... Check your compressor it is working? compressor - The thing that make noise behind the refrigerator...
Posted on Sep 05, 2007
SOURCE:
Water is draing to the bottom catch basin in my Frigidaire Model FRT18B4A refrigerator. Under the 2 bottom drawers there is a catch basin. It takes a week to fill with water. I spounge it out before...
The source of that water is from the automatic defrost cycle in the freezer,the water is supposed to run through a drain in the freezer but that drain is blocked so the water is draining into the refrigerator vents and ultimately to the catch basin instead of draining .
This tip i wrote will help ya to clear that drain in the freezer http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 16, 2011 | Frigidaire FRT18B4A Top Freezer...
DGHS2644KF2. Water leaking from bottom onto floor about once a day or less. I have shut off the supply line and the leak persists. It appears to be the drain line from the condensor (evaporator?) which is...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 23, 2011 | Frigidaire DGHS2644KF (260 cu ft) Side by...
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
GE Monogram bottom freezer leaking water from left side onto the freezer floor and onto hardwood floor of the kitchen . Already tried totally defrosting freezer and that did not solve problem. Help!!
ck the drain in the back of freezer . it may be pluged and when it goes into defrost cycle you get about a cup of water on the floor . if there ice on bottom of freezer then the drain is iced over . some models require a drain heater to prevent this . mm hope this helps ..
Oct 14, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Leaking water periodically under the refrigiater
When a refrigerator leaks water like yours, it is common for the problem to be nothing more than a clogged defrost drain. When the unit defrosts itself, the frost melt water drips into a pan underneath the evaporator in the freezer, and goes through a tube from there to the bottom outside of the unit. Since the water cant go down this drain, it backs up on the freezer floor, then eventually the kitchen floor.
Oct 06, 2010 | Frigidaire FRS26H7C Side by Side...
Frigidaire FRS26ZNH frig is freezing water in the bottom of the freezer and is leaking water onto the floor. i have looked for a stopped up drain plug or hole with no success. please help. john
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Frigidaire Refrigerators
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
So water leaks out onto floor-Jennair side by side
THERE IS A DRAIN LINE HEATER ON MOST UNITS now days, if yours is an older one what you need to do is make sure that it's level, and that the drain line is cleared so that the water has a place to go when it thaws during the defrost cycle.
Jan 27, 2009 | Refrigerators
FRIGIDAIRE FRS22ZRGD2
you may need to clean the drain tube again. the only other place that water may come from is the ice maker if it is over flowing. this however would be very obvious. use some thing like a length of cloths line cable to "snake" the drain after you defrost it. the fastest way to defrost it is to use hot water and a turkey baister. good luck.
Sep 26, 2007 | Frigidaire FRS26R4C Side by Side...
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
