Question about Foxconn P4M9007MB-8RS2H Motherboard
Front connection don't seem to work
Have gnd, mic l & r how are they connected to f_audio?
    Master:
    Sergeant:
  • 461 Answers
It should be in the manual..if you do not have one..you can get it here http://freeguide2u.googlepages.com/datasheet.html
Posted on Sep 05, 2007
  • SS s
    SS s Sep 21, 2007
    May I know why my comment is not helpful to you?
Hi! i am using Intel DG33FB motherboard, i need the information about the connectivity of front pannel audio. for this it is Realtek HD audio port. i am having 5 cables set for the front pannel...
The L&R-Ret2&3 are common so only one needs fitting so for the speakers you only need to connect 3 cables. R-Out, L-Out and one return (either L of R). I'll comment back shortly on the mic pins for you.
Dec 23, 2010 | Computers & Internet
Hello. When I plug my headphone with mic into the front panel jacks, it does not work. Now if I disconnect my speakers and plug it in the back jacks, it will work. However, the front joacks are there for...
Open up your case.
You should see cables running from the front panel to the motherboard. On the motherboard you will see a multi-pin connector. What is your exact ASUS motherboard model? Here's a generic ASUS one. You will see this on the motherboard where the front panel connects to the board. A bunch of pins will terminate here.
Notice the pin labelled MIC. You will see GND etched on the motherboard. Use this to orient yourself. The Mic one is just below the GND pin. Connect it here. Notice the entire top row is devoted to FP_Audio or Front panel Audio. There are other places to connect it (e.g., if you just want stereo sound, there's a left and right FP_R and FP_L).
Move the mic connector over to the Mic pin if there is one. If not, you can get a cable at your local computer supply shop. As you can tell from the others, they are very basic wires with simple terminals.
Sep 03, 2010 | ASUS Computers & Internet
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
Asus p5pe-vm front panel audio connector (10-1 pin FP_audio)
F_AUDIO <==> CASE
1- PORT_1L == MIC_IN
3- PORT_1R == MIC_PWR
5- PORT_2R == R_OUT
9- PORT_2L == L_OUT
-------------- OTHER SIDE ------------- (case wire)
2- GND
4- GND (other)
6- R_Return
8- key
10- L_Return
May 16, 2008 | ASUS P5PE-VM Motherboard
Hi i have a problem connecting the front pannel mic and standard audio connections to my winfast k8m890m2ma motherboard the manual shows where the 8 pin "front audio connector" is like this...
It is a bit of a problem when you have single connectors but here goes. You use the Front Audio connectors. The manual says you have :::.:
If you turn the board round until the dots are the same way round as above. Working from left to right.
Bottom row. MicIn, MicBios, SpkoutR, empty,SpkoutL
Top row GND, empty, returnR, blank space, returnL. Now this is the tricky bit. Try the power if it works OK. Because the board and the case manufacturer work to different descriptions, try this as an alternative. You may have to swap over the two connectors for GND and Mic Bios.
Mar 10, 2008 | Computers & Internet
Foxconn P4M9007MB-8RS2H Motherboard Logo
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
