Question about Magic Chef Kitchen Ranges
How do I light my pilot light on 1984 Magic Chef gas range
The numbers on the oven knob on my Magic Chef gas range have worn off. My pilot light has gone out and I dont know how to light it. Can you help me? Thanks in advance.
  • SENDROSES Jan 26, 2008
    how do i light the pilot on this oven
    do i light it in the back
    do i reach back under the lower broiler
    do i let the gas run for a moment and just swing a match under the broiler?
    does anyone know how to light this oven?
    thank yu in advance for yur response
    be blessed friends
  • 1314 Answers
SOURCE: magic chef range
if you give me a model number i be might be able to help try here get your model number off the serial plate from the range http://www.maytag.com/support/manuals_literature.jsp if that dont work reply to this thread with model number
Posted on Jan 15, 2008
  • 1314 Answers
SOURCE: Magic chef oven
change the bottom ignighter just because it glowes doesn't mean its getting hot enough to open the safety valve you should see two screws at the bottom of the floor of the oven cavity after removing the racks remove those and remove the floor then you will see a deflector shield remove that to get access to the ignighter take out the two screws and install the new ignightor and reassemble
Posted on Jan 21, 2008
Master_Tech
  • 770 Answers
SOURCE: magic chef propane oven. recreation vehicle application
you need to check the amp draw on the ignitor.. if it is between 3.5 -5.2 amps your gas valve is bad..if not the ignitor is bad..YES theignitor can glow and still be bad due to lack of amp draw to open the valve..check that and let me know
Posted on Feb 22, 2008
aborcass
  • 2651 Answers
SOURCE: Magic Chef 61EA-3KX oven knob hard to turn
nothing magical here, sounds like the thermostats on its way out, not servicable part needs replacing.
Posted on Feb 26, 2008
frcs68
  • 1605 Answers
SOURCE: How do you light the oven pilot on Magic Chef 31000PAW
open the oven. take out the racks and push on the button plan toward the back and left it out of the oven.
you will see a small orfix appromiate middle of the fire ring. light a match to it. put eveything back.
you in business.
Posted on Apr 07, 2009
I have an early 70's Magic Chef series VI oven/stove. The stove works fine. The oven takes about 30 minutes to light. When oven knob is turned pilot works fine. There is no gas odor before the oven lights.
My model is a UA119A-2W and I cannot find a place to light the oven pilot. Nor can I find a copy of the owner's manual anywhere online. Any suggestions would be appreciated.
Apr 05, 2010 | Magic Chef 31000 Gas Kitchen Range
I don't have the model number for this range but it's a very old magic chef gas oven. What I need is the oven temperature knob. The knob used to have all of the temperature numbers printed on it however...
If you go any hardware store (Lowe's, Home Depot) they have universal knob replacement kits. Take your old knob with you and ask for help from someone who looks like they know something (the old guy). Its so much cheaper this way, exact replacement knobs can run $20 or more each. Good luck!!
Jan 16, 2010 | Magic Chef 9122 Gas Single Oven
My magic chef kitchen range oven won't turn on, no gas
Some of the models require you to push in the oven thermostat knob to set the pilot if it blows out. So try pushing in the knob and hold it while lighting the pilot. When the pilot lights continue to hold the knob in for about a minute. When you let go of the knob the pilot should stay lit. If it does not stay lit then try it one more time. If it continues to go out the thermocouple or aso might be bad and will need service.
Sep 11, 2009 | Magic Chef 31000 Gas Kitchen Range
I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Cpr1100adw magic chef
Most, if not all, gas ovens do not have pilot lights any longer. They are electronically ignited. You could have a loose wire on the igniter or a faulty igniter. If your oven is new it should be covered by the warranty.
Jul 26, 2009 | Magic Chef CPR1100AD Gas Kitchen Range
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
you in business.
Apr 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Oven not working - strong gas ordor
man that is an old oven, according to the diagram ther is a pilot light in the oven compartment , access form the lower drawer/ cover panel, looks like a pilot for sure and problably has blown out
Nov 25, 2008 | Magic Chef 31000 Gas Kitchen Range
Kitchen Ranges Logo
287 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Sal De
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
