Question about Toshiba 65HX81 65" Rear Projection Television
Toshiba 65hx81 65" Rear Projection tv. black & white color/green
What could be the problem with this TV? I bought this set 5 years ago new and as you would know it the extended warranty has just ran out last month. While watching it the other day we slowly noticed the picture color fading, then green, now it looks black and white or gray. It doesn't matter how many times you turn the TV on or off the color is not right. I disassembled the set and it appears that the green, red and blue bulbs are on and producing light (not sure if they are producing enough light though). While looking into the rear mirror, to me it seem like the bulbs should be brighter, not sure though. While working on the set all the bulbs became really bright and the color was fine for a minute, then instantly went back to the gray/green color. Has anyone experienced this problem and know what the fix could be?
  • eadair Sep 06, 2007
    I pulled the Toshiba Technical Bulletin that described the fix that you suggested (TV0201 REF # 012902). I checked the continuity connection to the main board on both the positive and negative connections to c810 and c809 and both were fine. I checked the fuses on F801 & F860 and those were fine. I am looking for more suggestions to fix this. Do you have any more suggestions or did anyone else experience this problem and know what the fix is? Thanks Techman for your help!
  • 3,130 Answers
Yep, your problem is a relatively easy one to repair if you know how to solder. You better repair it before it blows the fuse though. There are two capacitors in the main power supply that are coming loose and need to be re soldered. There is a Toshiba service bulletin about it. They are marked C809 and C810 on the main power supply board. Good Luck
Posted on Sep 05, 2007
  • Larry  Dillon
    Larry Dillon Sep 06, 2007
    Did you try to resolder it though, as if you did not, you should know, under a current draw the connections can go bad. If that does not work, replace the regulator IC.
Hi i have a convergence problem bought tv 5 years ago 2 techs have looked at it and have replaced convergence sensor unit and digital convergence unit but now tech says i need a convergence board and not...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Feb 02, 2010 | Toshiba 51H83 51" Rear Projection...
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
Jan 01, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Toshiba 50HX81 only showing black and white
I bet it's a DLP TV correct?
This symptom would indicate that the color wheel has flown apart. Which results in a monochrome only image.
Color wheels are expensive and need to be replaced by a qualified service person.
Dec 26, 2009 | Toshiba 50HX81 50" Rear Projection...
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Dec 07, 2009 | Toshiba 57H83 57" Rear Projection HDTV
No green color in picture?
its a simple fix. just go to your menu in TV adjust the RGB color. balance the RGB settings.
May 26, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Hitachi loses color
you are losing one of your color tubes for it to be goiing to black and white.
Jan 27, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 43vs9ua rear projection tv picture problem
I also had a same one but had the same problem. Thinking of throwing it away!
Dec 25, 2007 | Televison & Video
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Picture has a green shade
Sounds like your red picture tube is not emitting enough brightness to balance the colors. A temporary solution could be to slightly increase the screen voltage of the red CRT to give a good black and white picture when the color control is turned all the way down. If the set has not been serviced in the last 5 years or so, and you're not ready for a new HDTV set, it may be worthwhile to get a technican to look at it and clean the dust off the lenses and mirror and evaluate whether a picture tube rejuvination might work along with the gray scale tracking adjustments.
Mar 10, 2007 | Toshiba 51H84 51" Rear Projection...
Toshiba 65HX81 65" Rear Projection Television Logo
555 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
