Question about Brother HL 1440 Laser Printer
Print Error My pc can see the printer cause I deleted it and plug and play picked it up, so I know it's not a connection problem. But I can't print from any program to it. I've downloaded new drivers too. Restarted. It will print a test page but only when I shut it off and hold the button. Trying to run it from properties gives me the same error. I find the error when I open up the spooler and it says error-printing under status. Hope someone can help me. It's for work so I'm stuck without it. Thanks, Tara
  • Brother Master
  • 1,113 Answers
Unplug usb, delete driver and software, download driver and software package from brother web, only connect when prompted.
http://solutions.brother.com/index-asia.html
Posted on Dec 30, 2007
What does the error message - 49.4C02 - mean?
49 errors are often caused by the printer receiving commands it does not understand. Sometimes hardware failures but not often. To determine hardware or software, turn the printer off. Unplug any network or USB cables attached and turn printer on. If it will come to ready with no cables attached, then likely you have a print job that is causing problems. This can be fixed by installing the latest firmware from HP.com. Download the Easy Firmware Update Utility version. To install this update you need to have the printer connected to the computer, so check the print queues to make sure that there are no print jobs pending, delete them if there are. Plug the network or USB cable back in. Wait a couple of minutes to make sure that the 49 error does not come back. If printer stays on ready, run the upgrade utility and your problems should be gone. If it is a hardware issue then a different set of trouble shooting steps applies. Post back if this does not fix your problem.
Aug 15, 2014 | HP CP3525DN Color LaserJet Printer
Printer keeps saying busy printing another document
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
An error occured while printing
  4. Reboot computer.
Jan 12, 2012 | Lexmark X6675 All-In-One InkJet Printer
An error message reads printer cannot communicate with this computer. I have checked the firewaall, the installation and it makes copies so its a connection problem
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 19, 2011 | Lexmark X5470 All-In-One InkJet Printer
Printer D2460 blinks not print
The HP printer may print incomplete characters. This issue occurs due to clogging of print heads. So this problem can be solved by cleaning or replacing the print heads. Sometimes the printer will not accept the paper tray. At that time, you have to turn off your printer and disconnect the printer from its power source and reconnect the power and then turn the printer on. The printed pages will sometimes come out skewed, this may be due to curled or torn paper become jammed inside the printer. One easy remedy for this problem is that, you have to remove the torn pages from the paper tray and smooth down all the curled edges of the paper. If the settings of the printer are not correct or the paper tray is overloaded, the printer may pick multiple pages for printing, which could result in paper jam.
Get more help to fix HP Printer Not Printing error. Hope this helps you.
Jul 04, 2011 | HP Deskjet 2460 InkJet Printer
To print or preview publication at least one printer must be installed on the system
Have you checked if the printer cable is connected properly ?
there are 2 possible causes for this error to pop up.
1st : The software you are using to print, has not selected the printer as default.
you can disconnected the usb cable and re-connect. If this does not work, Try and check if you can print from any other application like word, excel or notepad.
2nd : The Printer drivers are deleted and you may need to reinstall the software/drivers
Uninstall and reinstall the software and it should work.
Or Finally 3rd solution is you can just turn off the printer and PC and turn on and try to print
Regards,
Ron
Mar 28, 2011 | Samsung CLP 300 Laser Printer
49.2f9d error hp laserjet 3005dn how to solve the problem
Most times a 49.xxxx error on an HP printer is caused by either the print driver, firmware or the print job itself.
If it happens when printing a PDF file try sending the file to the printer as an image.
Upgrade the print driver and the firmware.
You may need to disconnect the printer from the pc or network, power it off and pull the plug for a couple of minutes to clear the error.
If it's a network printer it would be a good idea to check the printer queue for any jobs still in it and delete them before powering the printer up again.
Dec 14, 2010 | HP LaserJet P3005 Printer
I have an HP printer. There is a full page photo that will not print. When I try to cancel the job is states deleting but does not delete. It deletes other added print jobs but not that one which is...
You have to clear out all documents one by one in the print que before you can delete the one causing the trouble. On the bottom right side of your pc screen, find the picture of the printer and right click with your mouse on it. Open your print que and right click on each document and choose "delete" until therer are none left in the print que. If this does not clear that last document, then unplug your usb cord that connects the printer to your pc and wait a few moments, and then plug it back in. This should clear it out.
Sep 08, 2010 | HP Officejet J4680 InkJet Printer
Printer busy/or error
Sounds like your machine is using DHCP, not a static IP address?
Print your network settings from the Printer, then try to Ping from a computer on the network.
Check the Network setting of the machine, make sure it is set to a fixed (static) IP Address.
If this is the problem, you can go into your PC printers port and change the port to the reassigned IP Address of the machine.
If you reinstall the drivers then you will have this installed twice, one will work one will not, so delete it from the printers folder before you reinstall before you reinstall
Sep 28, 2007 | Sharp AR-M277 Black and White Copier
Brother HL 1440 Laser Printer Logo
115 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
