Question about Nokia 9300 Smartphone
Rebooting i run out of battery and i changed to use my spare battery but after the change, my phone keeps restarting and telling me system and some application error. the phone keeps restarting every time i switch it on
  • zubu Feb 24, 2008
    how to reboot
  • 452 Answers
There may b two reasons that the particular point to which battery attaches has gone bad so ur cell is not getting proper current,, so change it pliz..either u need to flash the software of ur handset.
Posted on Oct 19, 2007
Dell dimension 3100 keeps rebooting
1. Click Start > Run and type REGEDT32 and hit ENTER
2. Click the plus sign next to HKEY_LOCAL_MACHINE
then System
then CurrentControlSet
then Control
then click CrashControl
3. Double-click on AutoReboot on the right side and change the value from 1 to 0.
Close regedit and restart the computer. Now the computer should shut down normally instead of restarting.
Feb 26, 2012 | Dell Dimension 3100 PC Desktop
Hp dv9208nr with vist sp2, system keeps rebooting, screen stays blank, cant even get to bios
When the files in your system are corrupted, your HP laptop would reboot automatically. When the files which are required to run the Operating System like fonts under Windows FONTS directory are been smashed then your system's Operating System will force your HP Laptops to restart continuously. Thus in such a situation you would have to change the name FONTS in the Windows directory.
Get more help to fix HP Laptop Keeps Rebooting error . Hope this helps you.
Apr 24, 2011 | HP Pavilion dv9000z Notebook
I've powered my 9620 off/on, moved the phone to a different desk. I keep getting DHCP Conflict and the phone keeps rebooting. I am not able to CRAFT... does not work on this phone at this point.
Someone configured a static IP on your network. The DHCP server thinks that IP is free and keeps handing it out to you. You can either trace the equipment (workstation or phone) that has that IP or you can go into the CRAFT menu and assign a static to the equipment (please check with your network or system administrator to see what IP you can assign to your phone. Also talk to your network admin if you are using VLANs)
To get into the craft menu and change the ip address settings
1. during the startup of the phone press the * key when you see "* to Program" during initialization
2. enter 27238#
3. navigate to the ADDR menu
4. change the ip address, call server ip, subnet, router to the correct ip addresses
5. if needed change the http, https, or file server address
6. restart phone
Mar 08, 2011 | Avaya 9620 IP Phone
My phone keeps shuting down and rebooting when I try to read a text. Sometimes when im sending a text it shuts down too
Dear Sir! the problem is with your cell phone's battery, you cell phone's battery is probably tripped. You need to change the battery, hope that will fix your problem.
Thank you!
Aug 02, 2010 | Motorola Mobility Rival A455 Cell Phone
Pc restarts and restarts till warmed up
There is a memory diagnostic tool from Microsoft. Search google for a download. Its run from the CD and check any issues with the RAM. As such there is no sure way to tell whether mobo is faulty. Bdw CPU if faulty will NOT run at all; only it can be over-heating. While formatting choose the quick format option not the extended one.
Apr 29, 2010 | Computers & Internet
Keeps rebooting itself over and over
Symptom: My blackberry BB keeps rebooting and restarting; endless loop.
Solution: Remove battery, Re-Insert Battery, replace case backing & PRESS & HOLD on back of casing when reboot gets to just before home screen.
Keep holding until home screen comes up completely and everything loads. (usually 10-15 seconds once home screen appears)
IMPORTANT: WHERE to press & hold back of phone/battery casing when rebooting;
On back of phone casing there are 2 gold strips that hold 2 gold nodes on phone down. THIS IS WHERE you press.
In essence you are firmly holding these nodes down with back casing on, just as phone reboots to home screen.
Works every time for me. Hope it works for you.
Jan 23, 2010 | RIM BlackBerry Bold 9000 Smartphone
Rebooting problame
Try a software update if there is one available for the handset, use Nokia software updater...
May 08, 2009 | Nokia 3110 Cellular Phone
Dell xps 1530 keeps restarting and running diagnostics, after it runs it, it restarts, windows won't boot. I tried using back up cd for operating system and it tells me it is the wrong disk. Also, all the...
restart safe mode press f8 as soon as pc turns on tap it... then select safe mode doesnt matter really which one as long as it works i always use safe mode with networking so i can get online then you need to goto right click on my computer properties then advanced and turn off restart automatically on system error and then you need to find out what the problem is.... thats causing it to restart there should be an error message that pops up now instead of just rebooting write it down and post it or google it
Apr 12, 2009 | Dell XPS M1530 Laptop
y hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is do i charge or change the backup battery?
Feb 17, 2009 | HP iPAQ h6315/h6365 Pocket PC
Keeps on rebooting
The processor fan should have failed. check it out.
Feb 17, 2008 | IBM Netfinity 3500 M20 8657 Server
Nokia 9300 Smartphone Logo
85 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
