There is sim slot in laptop. Just the tray out and put sim in it and insert again. You must have drivers for WWAN and PCI card drivers for this to work. After inserting sim tray in laptop back you system will detect it and open the WWAN software and try to connect.
You either have a dual SIM card phone (it can use two SIMs with two different phone numbers) or you're confusing the MicroSD memory card slot with the SIM card slot.
If you truly have a dual SIM card phone, just put the SIM card in slot 1. Your phone's user manual should be able to offer further info.
here for the modem . You will need to select your operation system then go to Software - Solutions > and download HP Connection Manager . If it still does not work you may try to download some of the Driver - Network drivers but i'm not sure which one will work.
Do you mean a card reader????? not sure if the s10e or any model lenovo actually uses a sim card, but if you are referring to the card reader i would imagine that the drivers are not installed for it here is the link to that driver, make sure you select your Operating system and then choose card reader on the list and download and install the newest version of the driver.
That slot is an ExpressCard Slot for WWAN cards that require a sim card in order to
connect to the provider's network. Not all WWAN cards require sim
cards to connect. If you get an ExpressCard WWAN card, and that card requires a sim to
connect, then usually there will be a place on the card itself to put
the sim. The sim slot in the battery bay is because most mini-cards do
not have room to add the required sim card slot and still fit into the
system.
Check the card with another computer or using the camorra with card inserted. This lets us know the card is working and will store information. If the card checks ok, then go to the Laptop and look in the device manager for flags, while camorra is hooked up and turned on. If you find flags, remove them and reload drivers.
