Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Intuitive Iw509nw fault code 9 what's it mean
Intuitive Iw509nw fault code 9 what's it mean please
    Champion:
  • 242 Answers
The size of the machine needs to be set. if you recently replaced a board the first thing you need to do is 'size set' the machine and instructions should come with the board. holding wash temp up/down and pressing power should get you into the menu, though it's too much to explain here.
Posted on Dec 11, 2013
SOURCE:
ngfam1
  • 639 Answers
SOURCE: fault 130 what does that mean on a F&P Intuitive washing machine.
Dear gink,
ngfam1 here for you!
I am happy to be of assistance!
FIX IT NOW BEFORE IT GETS WORSE AND COST MORE!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Pleas egive me a good rating here in fixya.com before you sign out!
Posted on Aug 26, 2008
SOURCE: Fisher&Paykel Intuitive eco IWL 16 Auto washer Fault code 51
Our washer did the same but it was after I took the excess drain hose and pushed it into the drain in the wall. I thought it looked "more tidy" In doing so I created a siphon effect. Once I pulled the excess hose back out it was fine.
Posted on Feb 14, 2009
  • 441 Answers
SOURCE: Fault Code 37 Intuitive Washer -
you have a clogged diverter valve, its blue and looks like a Y, it will need to be replaced, if you want call 1-888-936-7872 they can order the part and walk you thru replacing it
Posted on Jul 10, 2009
  • 4 Answers
SOURCE: top loading intuitive washer says fault code 37
This machine calls this error number for most faults.
So first let us know what stage it stops at.
The most common fault is blockage in the pump.
Remove the power plug, disconnect the 2 water hoses and tilt the machine onto its front.
It is simple to remove and replace. Disconnect the 2 sockets from the pump The pump is held in position by a latch on the left hand side. Depress the latch and twist the pump anti clockwise. Clean out , add a smear of vaseline to the rubber ring.
Reassemble in reverse
Posted on Mar 07, 2010
tbirdfan1
  • 3051 Answers
SOURCE: Washer Intuitive Fault code 12 Washer keeps
Hello there:
This code is a indication that your water inlet valve has failed and needs to be replaced when these valves fail they will continue to drain water into the machine even if the unit is unplugged
What you can do is to first unplug the machine and turn off the water to the unit then remove the hoses to the machine then youwill need to remove the back panel of the machine so you can get to the water inlet valve once you get to t the valve remove all of the hoses to it and the wiring and remove the valve then you can open up the valve and inspect it and replace any parts that are worn or rusted like seals or seats or simply replacve the entire valve itself this will cost you about 40 to 60 dollars ok once the valve has been repaired or replaced reinstall the water hoses and turn on then plug in the machine and if you have a cancel feature on it press that than you should be good to go from here run a couple of cycles thru it to ensure it is working properly ok
Hope this is very helpful for you
Best regards Michael
Posted on Dec 01, 2010
Hi there i got a fisher and paykel intuitive and i got a code 9 error.
Scroll down to fault code 9:
https://www.manualslib.com/manual/787840/Fisher-And-Paykel-Smartdrive-Phase-7.html?page=34
Jan 13, 2018 | The Computers & Internet
Intuitive Eco - code 49. What does that mean?
faulty cold water valve, if that doesnt fix it then fault computer board
Feb 27, 2015 | Fisher and Paykel Fisher Paykel Intuitive...
We have a fisher and paykel intuitive eco, which says code 37,
Hi just read your posting.Now ERROR CODE 37 means PUMP BLOCK ERROR.Is your machine draining any of the water out of it?Please reply with additional information on the question and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel Washing Machines
I have an Intuitive Eco Fisher and Paykel top loading machine. When I turn it on a continuous beeping sound comes on with the message Fault Code 49 apearing on the screen. What can I do to solve the...
Hi just read your posting.Error Code 49 means your Cold water valve is faulty,Or your control module is faulty.To test this fault you need an electrical test meter to test the water valve coil for conductivity.Have you or can you borrow a test meter to check the water valve?Please reply on how you would like to proceed and I am sure I can guide you throe the steps needed to rectify this fault.Looking forward to your reply.
Jul 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
What is code 105
Error code 105 means you have a Comms. Error Time out. This means there is a communications error between the display module and the motor controller.Now have you replaced a part in the machine recently?Just looked in my manual and it also says, to rectify this fault you might need to replace the rotor sensor on the motor.Please reply and tell me if the machine became faulty or a part was changed for another fault and then Error 105 started appearing in the display.Hope to hear from you soon.
Jun 04, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Jan 23, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive washer what is a code 43 please
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
Jun 09, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
May 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
184 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
