Question about Apex Digital AT2008S 20" TV
32" Zenith Television
When I turn on my television the screen is all blue and there is a red key in the bottom left corner.
    New Friend:
  • 76 Answers
This is due to electromagnetic field affected in the corner area. Check whether there is any magnetic components in surrounding area if found keep away from TV. And then switch off the TV and remove the mains plug also. Switch on the TV after 30mins. The colour will disappear. Even you got the same problem call technical person. Because the decaussing section is not worked.
Posted on Sep 05, 2007
SOURCE:
Apex model PF3225, The TV is Locked (blue screen with red key on the bottom left corner). Don't have original remote...please help
Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels
Mar 22, 2012 | Apex Digital PF3225 32" TV
Unlock apex tv model # AT2702
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Hope that helps..........
Jul 20, 2008 | Apex Digital AT2702 27" TV
Unlock Tv
Please view this FixYa Tip which outlines the procedure for removing the parental lock when the screen is locked on the Apex TV.
Thanks for using FixYa
Feb 21, 2009 | Apex Digital GT3215 32" TV
Tv shows blue screen
my tv screen is blue and has a red key at the bottom left hand corner
Oct 04, 2008 | Apex Digital AT2002S 20" TV
Locked tv
I'm having the same problem. My screen is blue with a red lock in the bottom left hand corner. None of the buttons work except the on/off button on the television.
Sep 14, 2008 | Haier HTF20R21 20" TV
Apex GT2015 20 inch television
TVs Power Supply Unit may be faulty and you will have to get it fixed.
Opening up the TV may void the warranty.
Its better talk to TV Manufacturer's Tech Support.
Jan 09, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Tv is locked the screen is blue with a red padlock in the top corner
my tv is locked & the screen is blue . how do you unlock it ?
Nov 30, 2007 | Televison & Video
Zenith blue corners
CALL ZENITH AND PROVIDE SERIAL NUMBER AND PROOF OF PURCHASE. THEY WILL SEND TECH OUT TO FIX OR REPLACE TV. THIS IS A PROBLEM WITH MANY PROJECTION TV'S BECAUSE OF A FAULTY PART.
Sep 02, 2007 | Zenith D60WLCD 60" Rear Projection...
Blue screen with key symbol
Very easy to fix!! On the remote theres a function button or an f also on the remote theres a mute button. While the tvs turned on press the function(f) button and the mute at the same time and it will unlock.. Good Luck..BTW this on came from APEX customer service!!
Jun 05, 2006 | Apex Digital PF3230 32" TV
Apex Digital AT2008S 20" TV Logo
42 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
