Question about Hotpoint First Edition FEW12 Front Load Washer
Hotpoint few12, machine not filling
Before the rinse cycle the machine does not fill with cold water. The water runs straight through the machine and out into the drain and after a few minutes active and prog end lights flash but after resetting the problem begins again. The trouble shooting guide in the manual states that this indicates the machine is not filling and to check that the pipes are not twisted or blocked. We have done this and there is nothing blocking the pipes. Any ideas?
  • 625 Answers
The timer, electronic or mechanical is not advancing to the fill contact. if mechanical the cam contact may be burnt. if electronic the gated triac [solid state relay] is burned up [replace]
Posted on Sep 06, 2007
SOURCE:
When the 'wash' cycle finishes, the machine stops at the 'rinse and spin' cycle, and the 'prewash' LED flashes.
Victor. The prewash flashing is indicating a water fill issue. Rinse uses cold water only. check for clogged inlet screen on the cold water valve, and check if there is a screen on the supply valve also. If the inlet screen is all clogged up at the valve on the washer, you can clean it with a little windex and an old soft tooth brush. gently brush away any sediment or debris. If no filters are clogged, you will need to replace the fill valve assembley.
Apr 10, 2014 | Hotpoint WMA50 Front Load Washer
Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Apr 13, 2010 | Washing Machines
Rinse cycle won't work
hi there.sounds as if your cold water inlet valve needs replaced....
regards Sir Galahad
Aug 18, 2009 | Hotpoint VBSR3100GWW Top Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Hotpoint FEW 12 filling problem
possibly overfilling, or blockge in dispenser or hose from dispenser to drum.
Oct 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Water fill
if there are 2 hose connections then it is hot and cold fill. if only one hose connection, then connect to cold only.
if two hose connections, then connect at ramdom. put on rinse cycle. if hot water comes in, then connections are the wrong way round and just reverse them
Sep 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
NOT FILLING PROPERLY
have you got the drain pipe going up to about worktop level of machine?
if the drain just goes downwards then the water just runs out as fast as it comes in. get a sililiar situation if you put drain pipe too far down a standpipe - then a syspon forms and water drains out
Jun 28, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint washer Won't rinse
your cold water valve will be your problem or you've turned the water supply off, if the supply is not off put the machine on to the final rinse if it fills it will be the main rinse valve gone. The cold water valve is a double one with 2 solaniods. Unplug the machine turn water supply off remove fill hose there are 2 screws keeping the top on, remove them lift the lid off.undo the screws that keep the valve on, take note wiring and remove pull the black hoses off, replace with new one. The resistance of the valve will be around 3.4 kohms
Oct 07, 2007 | Washing Machines
Hotpoint First Edition FEW12 Front Load Washer Logo
141 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
