Vertical black lines on my Thomson 42" Plasma
Hi, I Have a problem with vertical black lines appearing on my screen, when i turn the screen on it generally takes about 30mins before they appear, sometimes its one sometimes 2 & very rarely 3, if i leave the tv on, again normally it drops back to just the 1 line after a short period of time (if i'm really lucky they all go away), the lines are roughly an inch thick and keep changing places!! Any suggestions would be much appriciated! P.S: was reading a thread on AVForum and people having the same problem with a Hyundai model said it was a dry joint problem & could be fixed by a little soldering, could it be the same problem?
  • 5 more comments
  • Smallsq14 Jan 07, 2008
    I have a Marantz PD-5020D Plasma monitor with a vircle black line at about the middle of the device running about 3/4 of the way down the screen. This happens on all sources, but looks nothing like a burn-in. Any ideas????
  • scuffer Jan 23, 2008
    I have been looking all day for a thomson web site,as i have a black vertical line down the side of my plasma tv of which i have had 3 years and the
    insurance has expired by 3 months,like yours it just appears when it feels like it.
    julie
  • ash_s Feb 11, 2008
    Hello, I have a 32" Emerson and I also have these mysterious black lines. It started as one thin blue line, that gradually turned dark. Over the past couple weeks many new lines have appeared, each a different color, all in a cluster by the first line. When I first turn on the TV, they are all really dark, but after the TV "warms up" a little, they go away, sometimes completely.
    There is no warranty or anything on the TV, that was the catch for buying it (we got it for a VERY good deal...) It didn't break my bank to buy it, I just want to know wtf is going on with my television. Thanks in advance for anyone's input...
  • Anonymous Feb 26, 2008
    i also have the lines on my screen...but also i have a line at the top that loops down showing about 1/2" picture above it
  • Anonymous Mar 20, 2008
    If anyone had this problem repair. Please email me at [email protected] I have 2 vertical black line on my Sony PFM-42v1plasma.
    Thanks,
  • stuart8862 Apr 11, 2008
    Hi
    Same problem Thomson 42" plasma with 2 x 1" vertical black lines down. One normally comes and goes, but the other seems to be there all the time now. Can anyone help me please call me if you can 07725 760069. Thanks
  • caroline11 Jan 02, 2009
    I have a 2 year old 32" Funai which has the same problem. After the TV warmed up the lines used to disappear but are now gradually becoming worst and are there all the time. Any ideas on solving would be appreciated.
    Thanks in advance
    Caroline
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Posted on Feb 14, 2008
I had a similar problem on a panasonic unit. It turned out to be a ribbon cable just above the affected area that had become loose during shipping. A tech came out and reseated it and it has been fine ever since.
Posted on May 01, 2008
    Problem Solver:
  • 5 Answers
Very likely same problem.  I have a Hitachi that was up to 5 of those annoying lines.  Found the AVForum thread and took it apart.  (Figured might as well try!)  Anyway, soldering and fixed...No more lines!
Posted on Oct 16, 2007
X driver cables 10 ohm resistors have loose connections
Posted on Apr 17, 2008
I had the same problem with my LG. It turned out that 2 PCB's needed to be replaced inside. It was an easy repair for thoes who know their way around electronics. It was the "Control Board" assembly, however your TV SHOULD be calibrated after the replacement of these PCB's. I have been unable to find a service manual to do the calibration myself and do not have the expensive equipment to do the calibration so I would suggest calling a certified calibration shop to do this part of the repair.
Posted on Mar 06, 2008
Yes, could be fixed by a little soldering but you need some electronic skills and cautions. remember that tv sets always remain charged with mortal voltages even after switched off.
Posted on Jan 14, 2008
SOURCE:
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Random 3'' vertical red line on 42'' Hitachi Plasma TV
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
1" black vertical line in center of screen. Sony Plasma.
NOT DEFECTIVE!!!
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable2_bing.gifnear the black lines. Unplug the ribbon cable and look for black chipson the underside of it, I think they say 100 on them, you need toresolder both ends on each chip. Should fix the black line issue.
Aug 19, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
May 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
Black vertical lines is there a fix My problem is with a hoizontal thin black line on my Dell 42" Plasma TV. Any suggestions for a fix? I had tried turning off and disconnecting from cable for awhile,...
I have the same problem. My repair shop says I need a new plasma screen. Dell says replacement screens are unavailable. I now have a 42" paperweight.
Jul 22, 2008 | Dell W4201C 42 in. Plasma HDTV
Vertical black line on screen
Your set has either a bad driver board or more likely a bad plasma panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 18, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
1,755 people viewed this question
Top Televison & Video Experts
Ekse
