Question about Akai LCT3285TA 32 in. LCD Television
BURN UP DIODE DE 008 BUNT UP
    Sergeant:
    Champion:
  • 346 Answers
Is that the number written on the circuit board?can you see what is written on the diode itself?
Posted on Apr 01, 2008
My vizio p4 is not coming on. when watching sometimes the picture would go off, i would turn the breaker in the off and on and it would work. this only worked for 2 weeks. then when i would press the on button the red light would turn green but i would not picture. I would not work at all until i disconnected the built in speakers. i got more weeks use and then it happened again. i opened the panel an elliminated the ckt board that feeds the speekers but nothing. i did notice that when i turn the power on the dc plug on the main board which feeds power to the speaker ckt board has 300 vdc when first turned on after relay clicks on the main board the voltage starts to drop rapidly all the way to 5.6vdc. input voltage is good steady 120vac. thanks for any help.
Posted on Dec 24, 2007
    New Friend:
  • 76 Answers
Your statement is not clear. You did"t say which diode and what type of problem you get. Please give the chassis details and clear symptom you seen. Normally burnt up diode is due to overload, threshold frequency, current and bias factor. Your clear picture only much useful to guide you.
Posted on Sep 06, 2007
SOURCE:
You may have an exit sensor POB that need adjusting or replace registration assembly
Aug 20, 2014 | Xerox WorkCentre 7328 Multifunction laser...
Como programar un control de dish a una tele panasonic
Depende del modelo del control remoto. Pero en general:
Press and hold the desired mode button (about three seconds) until all mode keys light up, then release.
Use the number pad buttons to enter the three-digit number corresponding to the equipment. The light will blink off after each digit is entered and then return to a steady light. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works, try several functions for that equipment.
Panasonic TV: 508, 509, 510, 511, 512, 566, 574, 575, 628, 644, 651, 662, 663, 668, 672, 673, 676, 685, 687, 689, 698, 697, 700, 706, 714, 716, 234, 247
Panasonic: 008, 009, 010, 011, 012, 066, 074, 075
Mar 05, 2011 | DISH Network IR Remote Control
I have a 2001 trooper that it smell like bunt oil someone told me that i need to change the oil and that a trooper has diffrent places where diffrent oils need to be put and change.
Yes you do need to change those fluid pre you maintance, but if you smell burn oil you could have an oil leak some where dripping on the exhaust mag giving you that burn smell, have it check out.
Dec 11, 2009 | 2001 Isuzu Trooper
I burn the dvd and then my computer says that the disc is empty, but I can burn cd's just fine?
Sometimes the laser diode for burning the cd and the dvd are seperate, and the one that burns the dvd is no good. It takes more lasing power to burn dvds than cds, and if it is a single diode, then maybe it has weakend, and can omly burn cds. Either way it is a bad diode, The whole laser assemble needs to be replace because it is hard to buy just the laser diode, and even if you buy one, you would not be able to align them properly, and they are very difficult to replace individually, I tried that once by taking a diode from another dvd burner, it did not work.
Aug 12, 2009 | HP Computers & Internet
Dear, I have a Toschiba lcd-TV 42X3000PG. In the power-supply(V28A00036500) their are 2 diodes in short circuit and the main fuse is broken. The 2 diodes are marked with "GA78" ,but i can't find them in...
If it is in Bridge rectifire then replace with 1N4002 Diode and it available in the market.. If in auxilary section better use BA159 ... Replace the fuse with same Amps..
Jul 10, 2009 | Toshiba 50H81 50" Rear Projection...
Blown diode
No. A diode holds a charge in one direction only the wire does nothing but burn open on excess current. Obtain the correct Diode from radio shack and replace. The ereal question is why the diode is blown..
Apr 08, 2009 | Computers & Internet
I need to replace the diode on a 4.8 volt NiCad 400m rechargeable
If you de-solder the diode, there should be a number on it i.e. 1N4000. You may need a magnifying glass depending on how tiny you can read. Once you know the number, you can go to DigiKey or another online electronic parts supplier and order it.
Mar 19, 2009 | Uniden HH9485 - Drop in Charger Fits the...
E2 error
Ponle un disco limpiador de laser a ver si esto soluciona tu problema si no es asi tienes que abrirlo y limpiar al laser con un cotonete impregnado en alcohol primero lo limpias con el lado mojado y despues lo limpias con el lado seco el laser es un pequeno cristal como ojo de pescado.Suerte
Apr 09, 2008 | Panasonic CQ-HR1003U CD Player
Need codes for GE television
I dont have your exact model but if one of these codes should work
000, 008, 009, 011, 012, 027, 038, 068, 086, 089, 091
Nov 30, 2007 | Zenith ZN110 Remote Control
Akai LCT3285TA 32 in. LCD Television Logo
87 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
KISHORE DESHPANDE
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
