Question about Ricoh Aficio CL2000N Laser Printer
My printer's nuts!
How can I get fix the "Replace Black PCU" warning on my RICOH Aficio CL2000N? Thanks!
  • LabMan Dec 04, 2007
    I have changed the Black PCU with a new OEM unit. I still get the warning on the LCD and can not use the printer. Any ideas on how to reset the unit or what sending unit is broken?
  • emptynest Jan 03, 2008
    Also replaced the Black PCU and error won't go away. I have tried taking out all PCUs and replacing, turning off and on. Error still there but it will print.
1. When the red replace color or black PCU light comes on you dont lose control of your printer. You can still print.
2 Most Ricohs have built in meters for the supply parts. The meter might need to be reset in this case.
Posted on Apr 18, 2008
I had the same problem. Since I knew my PCU was still good, I figured it was just the connections. I repeatedly fiddled with it - PCU in & out, wiped clean, held in place as I closed the latch plate. I finally got a long, skinny cleaning brush (a wierd feather-duster thing my wife uses for cleaning tops of books on the bookcases) and cleaned the slot out; that seemed to help. Note that I took great care because I was not sure what I was touching, and I did not want to leave any 'feathers' snagged inside.
Posted on Feb 11, 2008
You need to replace the black cpu, if you go to their website it will tell you how to replace it step by step
Posted on Oct 19, 2007
How to clear the pcu code
The printer is set to display the "replace PCU" message after a set number of copies. The only way to clear the message is to replace the color PCU that the message mentions.
Apr 17, 2010 | Ricoh Aficio CL2000N Laser Printer
My Ricoh Aficio CL2000N is printing several faint lines
Couple possibilities:
Fuser hot belt has wear lines transfering to the page
Black pcu needs to be replaced
Transfer unit is not being cleaned properly and needs to be replaced.
Remove each of these assy and inspect them for wear or lines that corespond to the lines on your prints.
Mar 25, 2010 | Ricoh Aficio CL2000N Laser Printer
Error code sc440
Black drum motor error. These machines are bad about the waste toner building up in the drum unit. You could try and take the auger out of the drum unit(very messy) and clean it out or try replacing the black pcu.
Mar 17, 2009 | Ricoh Aficio CL2000N Laser Printer
Thin lines along left side of Ricoh CL2000N laser printer
Printing B&W? Colour? or both?
Depending on your answer, replace the applicable Photoconductor.
Mar 02, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh CL2000N Error SC441
It means the PCU (CMY) motor error.
Try removing and reinserting properly the CMY PCU drum or replace it with a new one.
Jan 08, 2009 | Ricoh Aficio CL2000N Laser Printer
You may have to replace the transfer belt or the drum. I would start with the drum first
http://www.websitetoolbox.com/mb/copierquestions
Sep 02, 2008 | Ricoh Aficio CL2000N Laser Printer
Faded Printing
gfkhdsfagljsafsadfdsafdsa
Aug 05, 2008 | Ricoh Aficio CL2000N Laser Printer
Lines down left side of paper
replace the Black PCU
May 15, 2008 | Ricoh Aficio CL2000N Laser Printer
Error message says reset PCU correctly
You get this message because the PCU isn't seated properly. This is a link for the user manual for this printer: http://www.ricoh-usa.com/downloads/manuals/printers/cl2000.pdf On page 13 shows a diagram that indicates the photoconductor unit on the printer. Page 60 shows you different error messages, what they mean and how to fix it. It means you have to take out the pcu and reseat it into the printer, it is not in correctly. Page 29 shows you how to do this. It has pictures of how to take out the pcu and put it in correctly. I hope you get it fixed.
May 12, 2007 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
344 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
