Question about Sony Cyber-Shot DSC-P73 Digital Camera
My camera keeps switching itself off!
I've had my Sony Cybershot DSC-P73 since May 2005 so I'm almost not surprised it's acting stupidly as it may just be down to wear and tear as I use it an awful lot! But in the last week whenever I attempt to turn it on, the only timeit stays on is if it's in playback mode (when viewing photos/movies stored on the memory stick). As soon as I turn the wheel to a setting that requires use of the lens, the lens comes out, and then the cmera switches itself off (leaving the lens stuck out there, so I have to switch it back on in playback mode for it to retract again). I've had a good look at the lens while it's out and it's not bent, nor does there seem to be any other physical fault with it. I've also tried removing the batteries and warming them up before replacing them in the camera - on a few occasions, this has seemed to do the trick, and the camera functions as it should do again and allows me to take photos/movies. But sometimes the flash going off results in the camera shutting down again. And other times, warming the batteries does nothing to help. The batteries I have are what were with the camera when I got it 2 years ago - Sony Cybershot rechargeable Ni-MH AA 2100mAh. I have noticed recently (before my camera started doing as it pleased!) that they ran down very quickly - after using the camera for a couple of hours (for example, on a night out) the batteries would need charging again. I was wondering whether the problem is possibly that the batteries are no longer powerful enough to operate the camera? I've seen some stronger new Sony Cybershot 2700mAh rechargeables on the internet, and wondered if getting these would solve my problem? Or could it just be that general wear and tear has caused a loose connection somewhere in the lens, resulting in it not always working properly?
  • The RAJ Nov 16, 2007
    I had a similar problem with my daughter's camera. When it is turned on the screen would only last a few seconds before blanking out. She had to turn the camera on several times before the screen would stay on for a few shots. The original Sony batteries were recharged, but to no avail. However, we decided to follow the solution described and changed to newer batteries. The problem went away. It is apparent that even with batteries that are fully charged, they may have aged where they no longer have the staying power that newer batteries have.
Started getting the same exact problem recently, for a camera of similar age, short of tossing it into the floor in frustration, it seems it's the sony batteries, Even after taking them off the charger, the camera will not work, in any other setting but review and when the usb is connected. after replacing them with new ordinary rechargeable batteries, the camera seems to work fine
Posted on Oct 23, 2007
I ordered some new batteries for it before posting my problem ,a dn after using the new batteries, the problem no longer exists. It seems that my batteries were so run-down that they just couldn't power the lens anymore or the flash at times
Posted on Sep 11, 2007
4 Suggested Answers
  • 90 Answers
SOURCE: Kodak Z712 IS
How many pictures can you take with alkaline batteries?
The initial voltage of NI-MH is low and when it discharges, the voltage drop lower to a point where it is not high enough for the electric circuits of the camera. Alkaline batteries hold their voltage better.
Try SANYO eneloop recharchable batteries. They don't drop their voltage.
Posted on Dec 31, 2007
SOURCE: my digital camera turns on and qwicly turns off
it was fixed by it self
Posted on Apr 13, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: I have DMC-LZ8. I have
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Posted on Jan 14, 2011
Sony Cybershot Dsc-505
Are you sure it is your charger and not the battery? (Batteries)
You could buy a new Sony charger, but there are lots of universal camera battery chargers, that won't cost as much and you can use it for every battery from every camera. Pick the right one and you have a charger for years to come, whatever your new camera will be and how big or small the batteries are.
Jan 05, 2014 | Sony Cybershot DSC-F505, Cybershot...
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a...
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a message to power on and off again. I\'ve tried switching on and off a few times, removing battery pack and memory card, but nothing seems to be solving the problem.
Feb 19, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot DSC-5730 how to set date stamp
I;ve search in Google that many of Sony Cybershot camera don't have date stamp function. If you camera don't have either, maybe you can try to add date stamp with other software like TimeToPhoto software. You can download the software from this site :
http://www.avpsoft.com/products/timetophoto/
Hope this help (^_^)
Jan 08, 2011 | Sony Cyber-shot DSC-W70 Digital Camera
SONY CYBERSHOT DSC T2 keep shaking?
This is a known issue with the DSC-T20 Cameras.
Check this link for more information and get it serviced to resolve the issue.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT20&news_id=269
NOTE: Confirm the model # of the Camera whether it is DSC-T20 or DSC-T2.
Good Luck!!!!!!!!!!
Oct 08, 2009 | Sony Cybershot DSC-T200 Digital Camera
My digital camera screen will not turn on
This is a problem with the internal lcd components or the lcd screen itself. Have you downloaded the pictures off the camera? Your options are repair or replacement. Follow this link for repair through sony:
https://eservice.sony.com/webrma/web/index.do
Sep 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
How do I playback video on sony cybershot on the camera itself
Near Mode Dial, there is Playback button, press it to view pictures.
Jan 11, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Sony Cybershot DSC-P200 problem
I had the same problem with my camera a year ago I send it in to sony & they fixed it,for $20.00...
Jun 10, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Sony Cybershot DSC-P10 - Question from a newbie.
I'm not familiar with this particular model but I'm sure there wouldn't be a problem making changes to the settings while the camera is on. In fact, I'm not sure how you would accomplish a change or have the camera switch the setting unless the camera is on.
Sep 08, 2005 | Sony Cyber-Shot DSC-P10 Digital Camera
Sony Cyber-Shot DSC-P73 Digital Camera Logo
170 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
