Question about Apple iPod 3rd generation MP3 Player
Apple 5th gen video
Accidentally knocked out usb cable while updating - ipod now has the do not disconnect symbol permanantly on screen, locked sign wont go and will not turn off or do anything - completely frozen
Re: apple 5th gen video
Have you tried reseting the iPod (see product manual for how to reset your particular iPod)?
Posted on Sep 12, 2007
0 characters
3 Points
Is theres a number i can call for technical support for help to unlock my ipod nano
No Number but try this:
Screen Lock" is provided by the iPod nano, iPod (5th Gen), and subsequently released full-size iPod, iPod nano, and iPod touch models. Earlier iPods, and iPod shuffle models, do not offer this feature. In the Apple Support Site, Apple notes that the "Screen Lock" function:
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer. When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally -- not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
Oct 11, 2011 | Apple iPod nano
I got a new 5th gen ipod nano not reconised by itunes
I found this article on apples web site I thought it might be helpful
Apr 14, 2010 | Apple iPod nano 5th Generation
Model A1136 - What generation is this please.
It's an iPod Classic, 5th gen. Another way to tell gen:
4th gen = no video support
5th gen = video support, U2 on the box, no search function under music menu
5.5 gen = video support, longer battery, "search" under music menu, Johnny Depp/Red Hot Chili Peppers on the box, brighter screen
Jan 26, 2010 | Apple iPod MA446LL/A MP3 Player
Ipod woulnt connect to itunes
Reset your iPod:
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Then connect it to your computer and see if it is recognized by iTunes.
If not, try other USB ports on your computer, especially any on the back panel.
Dec 29, 2009 | Apple iPod nano
My 5th generation ipod just stopped working. I
Either the ribbon cable from batter/usb to the battery pack is loose, broke, or brittle, or the software needs to be updated which can be done from apple site under download or support tabs.
Dec 09, 2009 | Apple iPod classic MP3 Player
I want to know which generation is the Ipod 30G model A1136, thanks
There are two 5th gen iPods, A1136 model is the older 2005 model, not the later 2006 model.
Here is Apples link: which will show the differences, but not by model number. The reason I know this model number is the first 5th gen 2005 is because I have one. Also older 2005 should have '2005' engraved on rear.
May 29, 2009 | Apple iPod classic 5th Generation
IPOD 5th gen does not power up
well my ipod was fine, then when i went to open it up, my tool slipped and i knocked off a circuit in the motherboard. from their my ipod was dead. it didnt do a THING. hope that helps. and if you found help please let me know. thanks
Jul 08, 2008 | Apple iPod MA446LL/A MP3 Player
My ipod 5th gen
Try connecting it to a different computer with a different USB cable. If it still doesn't work, it'd be helpful to know more details (does the iPod work properly other than that, is it possible that the pins at the bottom of the iPod where you connect the USB cable are damaged?).
Jan 05, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod video 5th gen issue with downloading music
You should try using a different USB cable as it's very possible the cable is damaged. If that's not the problem, the logic board is probably defective and you can either replace it if you're comfortable enough opening your iPod or sell the iPod listing the defects on eBay.
Dec 08, 2007 | Apple iPod MA446LL/A MP3 Player
Ipod 5th gen (video)
Hmm, I don't know if I know the solution, but I'll give it a shot:
Do the normal automatic way of trying to find the driver then look in the hardware device list (control panel) you should see you ipod listed under other devices with a yellow triangle next to it. right click this line and select properties. then click update device driver. then DON't do the automatic find, instead click i will choose the device from a list. Click on "storage device" and voila! VISTA now finds a USB mass storage device and install it
Nov 06, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod 3rd generation MP3 Player Logo
62 people viewed this question
Top Apple MP3 & Digital Media Players Experts
 Mike M
Mike M
Ron Dufek
Ron Dufek
Raisin Brann
Level 1 Expert
Are you an Apple MP3 and Digital Media Player Expert? Answer questions, earn points and help others
