Question about RCA P52960 52" Rear Projection Television
RCA P52960 I HAVE A RCA P52960 I BOUGHT IN 2001 IT HAS A LITTLE GREEN SCREEN THAT CAME ON ABOUT THE TV GUIDE DEMO HOW DO I GET IT OFF? PLEASE HELP
    Genius:
  • 1,694 Answers
Try a combonation of buttons on front of tv-- hold vol up & chan up fo four seconds?? try menu & vol up for four seconds,etc. Consult o/manual?
Posted on Oct 08, 2007
My RCA P52960 52in. rear projection tv has what looks like a slight Fisheye lense look to it,the center being perfectly fine but all around the edges is a slightly blurry and can see all three...
We calling convergence problem.
Re solder fly back terminal ( transformer)
Replace pico fuse 400mA(little red box fuse) beside fly back.
Go to set up, convergence, select auto convergence and your TV will work perfect.
I will be here for any future question.
Thank you for visit fix ya.
Aug 04, 2011 | RCA P52960 52" Rear Projection Television
My RCA big screen picture messed up after one of my children fell nto screen?? How can I fix this
The picture on my 52 inch RCA Projection television has green, red and blue squiggly lines around the objects on the screen and the picture looks 3-D.
Oct 30, 2009 | RCA P52960 52" Rear Projection Television
Could use some help with a "bowed" picture on my RCA P52960
Is the convcergence ( Alignment) also off which gives the TV a 3D look around items on the screen? If so replace the STK730-130 on the convergence power supply
Jun 23, 2009 | RCA P52960 52" Rear Projection Television
We have rca tv model 52950 need year made
I have the same television and bought it brand new late 2001 and was delivered to my home January of 2002.
May 26, 2009 | RCA P52960 52" Rear Projection Television
Hello, my son accidentally broke the plexiglass screen on my rca p52960 tv. was wondering how to take unit apart. any help would be appreciated.
If your tv still works, then this will be worth it. Turn the set around and remove the screws that hold the particle backing on. From there, drain the high voltage from the flyback. You'll also need to be very careful not to damage the reflective piece inside. This can be removed also, but be very careful. If you loosen the chassis, you should be able to access the front plexiglass panel. If you have any doubts about doing any of this, please consider taking this in to someone who is certified. Remember: working on tv sets can be VERY dangerous. Especially if you don't know how to drain the 2nd anode. HIGH VOLTAGE!!!
Apr 20, 2009 | RCA P52960 52" Rear Projection Television
Rca p52731wk wont power on
check for bad or broken connections around the high voltage transformer......
Feb 24, 2009 | RCA P52960 52" Rear Projection Television
Rear projection tv broke
try resoldering the vertical output IC. This is a common problem the tubes blank out but sound and on screen displays still work 90% of the time its the solder connections on the vertical IC that causes it.
Mar 24, 2008 | RCA P52960 52" Rear Projection Television
TV is possessed
ok i have seen this happen a few times its common solution is to replace the front keyboard cuircit. i have also seen the infrared sensor problem. the processor thinks it getting a menu on command
Jan 31, 2008 | RCA P52960 52" Rear Projection Television
Red, blue and green vertical lines in middle of screen all functions are ok
tibs?? what are tubs?? Your problem is a convergence problem. there are two stk###-### you have to have a TV repair person relace for you . there may be some touch up alighnment needed also when IC's are replaced. Good Luck
Aug 14, 2006 | RCA P52960 52" Rear Projection Television
RCA P52960 52" Rear Projection Television Logo
110 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
