I've changed my dash lights out for Red and later Blue for a nice change. I had to pull the cluster (i.e. speedometer unit) out of the dash. You have to remove an trim pannel on the face of the dash to expose the screws holding the cluster in. Once you have them exposed you will then remove the screws and pull the cluster forward to get to the lights pluged into the back. If you want to change the color then this is the time to do it. You can find different colors at your local auto parts stores and some places such as Walmart.
Good luck, I hope this helped you out.
By the above procedure can I also replace the fuel indicator bulb?
