Question about Nikon (8320) (13-30x50 mm)
Nikon n60-autofocus Hoping that someone here can help. Seems that I am without auto focus...when depressing the button to focus...I just hear a fast tap tap tap....and there is not any movement. I have checked the placement of the lense and all looks well.
0 characters
1 Points
How do I load the ****** Marksman 177 cal repeater
hold in right hand, depress cocking release with thumb, pull back cocking slide (takes some effort) till it locks out, push in on the lower front of barrel to rotate loading port to the up position (this won't move unless the cocking slide is pulled back), load BB in the top hole that is exposed (or a pellet in the lower hole), push loading port back down flush with barrel, push cocking slide forward. Marksman is now loaded. push safety button in so it is engaged. When in an appropriate place to shoot a target, push safety button back with your right finger (safety is off) and squeeze trigger.
Oct 17, 2014 | Spotting Scopes
You will need top take it to someone you specializes in telescopes and can get you the right part and install it correctly, Telescopes are not everyday items you can get parts for anywear. Try a scientific store and ask around, they may know somewhere to take it.
Feb 23, 2008 | Fujinon Super 80 (25x80 mm)
Is there an adapter available to attach my Nikon D40 to my Nikon RA11 spotting scope?
Sorry but your out of luck with that combination. Nikon only made SLR adapters for their Fieldscope line of spotters, none for the Sky and Earth series. The camera adapters are very proprietary so you won't be able to use another manufacturer's SLR adapter to solve this one.
Best Regards,
Ben Lizdas
Sales Manger
Eagle Optics
Jan 08, 2011 | Nikon Sky & Earth 7455 (20-60x80 mm)
Can a nikon FSA L1 work with this?
hi there, your Nikon certainly will work with this telescope, but `you`ll need a T-ring adapter that adapt the lens mount on the camera body with the viewfinder on the telescope
hope this post will help
Jan 05, 2011 | Nikon Sky & Earth 7452 (20-60x80 mm)
2.5x8 variable leupold loses focus when change power
The only reason a variable power Leupold scope should lose focus when changing power is that the object you are viewing is too close to view on a high magnification. Try again while viewing something 50 yards/meters away, and if it still loses focus, then it probably needs repair.
Leupold scopes aren't user-servicable, and you wouldn't want to try to take it apart yourself, but that's okay, because Leupold has one of the best reputations among optics manufacturers for standing behind their products. If there's a problem, you can call their customer service department at 1-800-538-7653, or submit a request on their online form here:
Either way, don't give up on it. Leupolds hold their value, and you could probably even sell a problem scope to someone who is willing to send it in for repair.
Dec 19, 2010 | Spotting Scopes
Nikon N 60 has a problem - FEE appears in window and camera will not shoot
I just fixed this problem on my Nikon... It is very frustrating when this happens!
First the issue is on your lens itself. Make sure the ring closest to the body of your camera is set to 22, it should be in red while all the others are white. This will fix your problem!
Jun 15, 2008 | Nikon (8320) (13-30x50 mm)
ETX-90 Focus
I suggest trying a different eyepiece first to see if that's the problem. Otherwise, if it was moved without adequate protection, there is a chance the mirror was shifted or damaged. A damaged mirror can't really be fixed since it's specs are very rigid. If it turns out to be a problem with the mirror the best thing to do is find an expert on telescope mirrors to try and fix the problem.
Nov 12, 2007 | Meade ETX-90 (48x90 mm)
Nikon (8320) (13-30x50 mm) Logo
55 people viewed this question
Top Nikon Spotting Scopes Experts
Michael Thomas
Michael Thomas
Are you a Nikon Spotting Scope Expert? Answer questions, earn points and help others
