Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Maytag Washer: How to Remove Tub
By justinjustin on Sep 05, 2007
I want to clean between the inner and outer tubs of my Maytag Atlantis MAV6257 top load washer. I flipped the top off, removed the top plastic collar, removed the agitator and removed the four bolts at the bottom...but I cannot get the inner, white tub to budge. Please provide detailed instructions (or a link to a site with instructions) as to how to remove the inner tub/basket. I looked for a long time on the web but can't find the info I need. THANKS in advance.
Same Problem
Jan 25, 2009
-   http://www.fixya.com/support/t194228-maytag_washer_remove_tub
states to rotate the flat nut counter-clockwise.
So far, it's not budging.
But should it turn "counter-clockwise."
Instructions at
http://www.applianceaid.com/tub_seal_replacement.html
say the nut is left handed and opens "clockwise."
The nut is on really solidly. WD40?
Thanks for any help.
-   vole22
Jul 29, 2008
-   i have taken the bolt out of the agitator but can not get it out what do i need tho do to get it out-   rjohnson529
Apr 14, 2008
-   cannot remove the tube on my maytag top loader,  model number LAT7400AAW.  The agitator is out, the top rim and seal is out, but their seems to be no bolts in the bottom of the tub to loosen. their is a sort of crimped cap fitting that won't budge.  Help me if you can, please.-   micah100
Solution #1
posted on Sep 06, 2007
Somewhat Helpful)
Buffalo12980
Rank: Wiz
Rating: 84%, 1055 votes
Under the agitator is a flat nut with notches in it. this nut requires a spanner wrench that will fit into the notches. You can use a large channel lock plier. rotate the nut counter-clockwise. under the nut will be a seal. remove the nut and the seal and pull up on the inner tub. to replace you'll need to replace the seal. if the nut isn't too chopped up, use this to refasten the tub.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Aug 06, 2009
Not Rated)
jeannielee
Rank: Apprentice
Rating: 0%, 0 votes
I have used several remedies and products for a smelly top loading washer, but the odor persists in the rim at the top of the tub. I have tried cleaning as far in as I can with vinegar and bleach and tried spraying a disinfectant inside, but the odor persists.I took the fabric softener dispenser apart and cleaned all the gunk too. is there anything else i can try?
Was this helpful?
Yes
No
Solution #3
posted on Jan 28, 2009
Not Rated)
vole22
Rank: Apprentice
Rating: 0%, 0 votes
Depending on the particular model number of the washer, the flat nut may open either counter clockwise or clockwise (left hand screw).
Mine is LAT2300AA and opens clockwise. And nothing would work until I got the spanner wrench. Improvising just didn't do it. My parts store let me use it for $5 instead of buying it for $20.
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
elite oasis is that a quaitly machine
Answer
washing mashine not working properly...accidentally changed the setting...pls help
Answer
Hi, I have a Hoover HSW 2125M Washer/Dryer which has developed a fault which last ocured a few weeks... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
