SOURCE: my mouse key keep moving
In the Control Panel, select Mouse and the Pointer Options tab. Uncheck "Enhance pointer precision" and the problem may go away.
SOURCE: need to reboot i
This error means that your hard drive isn't functioning correctly. The computer is attempting to load the operating system off your hard drive but the computer can't find the operating system. There are several causes for this problem:
1. The hard drive has crashed.
2. The boot sector and/or operating system has become corrupted.
3. The hard drive has become disconnected from the laptop; this is unlikely but possible.
To determine what has happened follow these instructions:
1. Turn off netbook and remove all usb devices.
2. Turn on netbook and press whatever key enters the boot menu; often it is ESC or F10 - look on the first screen you see when you turn on the computer.
3. Look at the possible devices listed that you can choose from. If the hard drive isn't listed, then your netbook isn't detecting the hard drive likely because it has crashed. At this point you're going to have to take the netbook to a repair shop.
4. If your hard drive is listed, then it's possible that the hard drive is fine but that the boot sector has become corrupted. If you have access to a USB CD-Drive and a Windows installation disk or have a way to create a bootable USB flash drive, then there are some solutions that can be attempted. If you don't have access to these things, then you will have to take the netbook to a repair shop.
If you do have access to a Windows installation disk or can create a bootable USB flash drive, then post back to this solution and I can help you further.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
SOURCE: My Samsung laptop rv511 won't
Check in the back side you can see battery inside the laptop. Pull it then reconnect .if still same then make sure your battery is working fine. There should be issue with battery if battery is fine then you need to take it to nearest service center because there is problem inside the laptop like motherboard or circuit related issue. most of time laptop battery create this type of issue..So check the battery. Let me know if you need further assistance. Thanks for using FixYa.
SOURCE: my acer aspire 5551 laptop isn't starting up its
Hi
Check underneath and use a small screwdriver to open the small rectangular panel with the image of a stack of CDs near it. This is where the Hard Drive sits.
Check to see if the Hard Drive is properly fitted properly docked into its socket and screwed down or held down properly so it is immobile during use.
If this is not the problem, tap the Fn + the correct function key to enter the Boot Menu at Start Up and use the keyboard arrows to select the Hard Drive boot option.
Make sure there is no CD or DVD in the Optical Drive.
If none of these is the problem then, regrettably, your hard drive may have failed, so remove it and test it in a hard drive dock or an external 2.5" Hard Drive Enclosure.
If it has failed you will obviously need a new hard drive, bootable operating system disc, drivers disc and programs and security software to reinstall everything to the new hard drive.
Unfortunately, any data on the old drive will be lost.
It is very unusual for a Hard Drive to fail suddenly without some prior warning or signs of failing (the only realistic way would probably be through a drop, severe knock, serious mains power surge or mains power cut, incorrect shutdown procedure, or sudden disconnection of the power cable during use).
Back up regularly to an external storage device and do not ignore any warning signs. Also plug all computer equipment to the mains via a Surge Protector/Suppressor to prevent damage from power surges or fluctuations.
I hope this helps
SOURCE: i need to reboot my laptop but i don't know
Reboot essentially means restarting the computer. This is two types
1. Warm Reboot: where you go to start on windows task bar and choose shut down but when prompted choose restart. This way computer shuts down momentarily and restarts!
2. Cold Reboot: By this means you choose to shut down and again when prompted choose shut down! This makes computer off completely until restart by pressing power button.
Booting is computer Lingo for above procedures!
