Generac 13,000 Watt  / 13,000 Watt  Home Standby Generator Logo
Posted on Apr 07, 2009
Generac EPS-15 attempts to engage the starter while running
Seems to not sense the engine is running. No output at this time. Looking for schematics of all boards.
  • Anonymous May 11, 2010
    did you check the main breaker and fuses
RSG000
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Jul 09, 2009
RSG000
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
17575
Points
41
I work on these everyday. You most likely have a bad rotor or stater if the starter engages while running and no output. The no out put is making the generator think its not running causing it to try and start. If its not that then its the control board or voltage regulator.
1helpful
Generac XG10000E - wont crank. No sound at all. Battery is fine.
See following link
https://www.generac.com/service-support/product-support-lookup
Check fuse and connections between start switch, control board, and starter solenoid.
ENGINE CONTROLLER CIRCUIT BOARD
GENERAL:
The engine controller board is responsible for crank-
ing, startup, running and shutdown operations. The
board interconnects with other components of the DC
control system to turn them on and off at the proper
times. It is powered by fused 12 VDC power from the
2answers
Behind starter fly wheel only moves back not forward wil not start not start starter seems like its working spins
Disconnect the battery and then carefully remove the starter. Take the unit to a local auto parts dealer for a bench test. Starters have two separate functions, one spins the shaft to crank the engine, the other is called a bendix, which pushes the starter gear out to engage the flywheel, and then after the engine engages, retracts it (except in the case of starter/generator combo units which recharge your battery and power your vehicle's electricals while the engine is running) Always best to get a bench test rather than depending on apparent symptoms.
Snowthrower starter will not engage flywheel
It shouldn't engage the flywheel except during the moments when you're trying to start the engine. Any other time, it should NOT be engaged so it isn't spinning the whole time the engine is running.
1helpful
Generac 17kw standby generator, starter will not engage into engine, just spins
If it spins and will not engage it needs removing and the bendix gear on the starter is probably worn or damaged
Generac 40kw single phase generator starter engages after 30sec of running
For the over voltage there is an adjustment on the control board.
Should be tested with a load something plugged in.
The hertz might just come on when under load and adjusted too.
If you need more give a model number and whether it is 13kw or 40kw.
Generac 6500 1988 in R.V.Southwind Two things, both only occur in the morning or when cold (I am in So Cal so not that cold). First, when starting the generator from the dash board starter button the light...
See if there is an oil pressure guage on the dash. When you start the machine it probably has a low oil pressure shutdown which shuts the engine off when you release the start button. This is an interlock. Watch the oil guage and keep the start button engaged until you see oil pressure, release the button and it will continue to run at that point. Your second issue may be a function of the choke. If you are having to choke the engine to start, you may have to play with the choke position to keep from overfueling the unit which may cause it to stall and possibly backfire as it has to much fuel to be burned on the compression stroke, and is igniting occasionally on the intake stroke. Hope this helps. Marvin
Have to attach a red cable to a terminal on the starter motor.Howver cannot locate the atarter motor.Generac 8000 generator.Thanks
Some gensets have a reverse generator that actualy rotates the motor until running then switches back and produces power. But the starter could be in the front of the engine looking like a altrnator or some such device. good luck..
Aug 26, 2009 • Hammering
Guardian model #004722-0 liquid cooled generator. In manual or auto mode engine starts fine,then after about 15 seconds starter engages again while motor is running, then after about 10 sec. starter...
Hi Mike,
Your particular model generator uses the output of the generator to decide if the engine is running or not. You need to look at wires S15 and S16 at the control board to see if you're getting 120VAC while the generator is running. A quick simple test is to just see if there is output at the power wires that go to the transfer switch from the generator. The thing you don't say that ought to be happening is that the control board should crank the engine 3 times with a 15 sec or so pause in between crank attempts, then it should shut down and light up the "fault" lamp and quit.
Bottom line is that if you're getting 240 VAC across the output at the breaker, you've probably got a bad controller or wiring to it broken, otherwise you've got some kind of excitation problem keeping you from making electricity.
Regards,
Carl
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
