Question about Hotpoint Refrigerators
Fridge freezer the super freeze & super cool lights are both flashing at me like their is no tomorrow, I dont understand why? they aren't in use,i've tried manually switching them off (didn't work) i've checked to make sure the doors are closed properly (which they are) & checked the seal on the doors (which look fine to me)is their really a problem or has it just gone a little neurotic?
  • Blue star Sep 06, 2007
    the fridge freezer
  • 833 Answers
SOURCE: Haier HTQ21JSS - Freezer works fine but fridge won't cool
RFGirl, you didn't give me much...that said, try a full defrost of the unit. You probably have a buildup of ice caused by condensation. This is probably because the door seal isn't doing its job well. If the coils that do the cooling are not exposed, you must either wait for a full defrost...about 2 days or figure out how to remove the covering panels and go about melting the ice. If you do, be sure that any heating equipment...like a hair dryer...be kept from getting wet. If this happens again, you probably have low gas levels in the box...you'll need a tech. Be sure you unplug the box.
How to check for low gas: Once the unit is defrosted, start it up with the coil covers off...after about 5 minutes, you should see an even coat of frost at both ends of the coils. If not, wait 5 minutes more. If still not, you're low. Alternate method: Go round back and find the compressor...the big black thing. It has a couple of pipes sticking out. The largest is the suction line. Start the unit. Wait about 5 minutes. It will frost up. It should either get dry or form liquid condensate on it if you've got enough gas. If it stays frosted, you're low.
Hope this helps.
Posted on Nov 28, 2007
huuum
  • 750 Answers
SOURCE: freezer not working but fridge is
tratra72
You said,
I opened my freezer today and everything was defrosting. The fridge is working fine. I thought maybe did not shut properly so made sure it was closed and 8 hours later it is still not freezing. The fan is working but the air is refrigerator. HELP!!!
1.Try unplugging the fridge for 5 minutes and then restarting it! This may reset the system!
2.If the freezer is so full that the rear vents are blocked then this may happen. Because the fridge and the freezer share the air!
3. If not then the freezer and the fridge have different controls and the freezer control if faulty!
then you need service. ur site has good service companies in your are for our customers!
Bless You,
please give me a good rating before you sign off!
thank you
Posted on Sep 14, 2008
SOURCE: flashing lights super chill super freeze
this machine has a lot of bad reviews due to them over icing in the rear of the freezer,firstly try defrosting for 48 hrs as the ice is encased with polystyrene taking a long time to defrost,also apparently they have a valve that can be upgraded if you contact hotpoint,and lastly if it ever does run correctly then only fill the drawers so that the food is level (no more)with the top of drawer as this will reduce airflow in the frostfree section,good luck
Posted on Dec 29, 2008
SOURCE: Hotpoint Fridge Freezer FF187e - 3 lights flashing
Hi, I've just fixed this I think! it started making a noise then stopped then the fridge got really warm. In the freezer compartment unscrew the white cover, behind there I found the fan had got ice all around it and ice over a sensor, I have defrosted it and plugged it back in and it is cold again. However the super cool and super freeze are still flashing after several hours, but it is now cold. Better than paying Hotpoint £160 to fix it!
Posted on Jan 28, 2009
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Posted on Feb 24, 2009
LEFT DOOR OPEN OF FREEZER. CLOSE3D DOOR FOR 24 HRS. nOW LIGHTS FLASHING ON SUPER COOL AND SUPER FREEZE.
You will need to unplug and defrost the fridge for a few hours then replug the power. Leaving the doors open allows moisture to freeze on the evaporator while compressor continues to run confusing the control board
APPLIANCE911
Apr 10, 2016 | Hotpoint Combi FFFL1810G Graphite 297 l...
My kic fridge have 2 compartments. Freezer and fridge. only the fridge part dont work help please
The freezer is where the heat is removed from the box and cold air should circulate from the freezer into the refrigerator section. Something must be blocking the vent between the two. There is only one cooling unit; it cools the freezer and is also vented into the fridge for sub-freezing temperatures.
Nov 26, 2013 | Red Line Mens Classic Gmt Black Dial Black...
My hotpoint quadrio amber lights at the top of the fridge door are flashing is this anything to worry about - they are indicated with the words ''super cool'' and ''super freeze'' (sorry but cant find...
my hotpoint quadrio is causing problems the fidge part is no longer cooling the light is coming on but thast is all what can cause this. can anyone help
Feb 20, 2010 | Refrigerators
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Oct 19, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Refrigerators Logo
27 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
