Question about EliteGroup P4M800-M7 Motherboard
No video/ No Post on P4M800-Pt Mach Speed motherboard. Keyboard lights up, but that's a far as it gets.
  • hkb3 Jan 07, 2008
    My pc was working great with no problems. I shut down; two hours later it will not even P.O.S.T; There is no beep; black screen; nothing. The MOBO is a P4M800 with a VIA VT 8237R Bios. Any suggestion(s) appreciated!
  • Anonymous Feb 13, 2008
    similar problem. However, if I unplugged it from the power strip for a few minutes, mine would initially boot intermittently, then freeze after 10 minutes . Now it doesn't boot at all. No beep, no display. Hard drive lite is solid red.
  • 2,961 Answers
If you cannot even get to the bios, then either there is a memory fault, but normally there is a corresponding beep, or just a flashing cursor (-) or the bios chip is damaged, as the bios has to check all the peripherals first before it gets to the processor.
Posted on Sep 05, 2007
What's the normal cpu speed in p4m800 and why my cpu speed is showing zero
There is no 'normal' speed - it depends which CPU you have installed.
Jun 29, 2009 | Mach Speed P4M800 (890552603480)...
Mercury p4m800 motherboard drivers free download
(1) Manufacturer's Name and Computer Name; (2) Model Name and Number; (3) the ID of *********** board. if you have a problem finding it we can help you. (4) A sequence of events in detail, from a little while before the failure, during failure and after failure. Thank you very much for your consideration and decision to use our service... My name is Constantin (arzconst is my internal nickname with
Jun 13, 2009 | Mach Speed P4M800 (890552603480)...
I want to setup wake-on-lan with my motherboard
you have to enable this feature in BIOS, usually by pressing F10, F2, DEL, ESC, you may see the exact key listed to enter setup when the PC starts, this is when you enter the BIOS, After you get there you will see an entry for WOL if the Board supports it. Hope this helps, thanks for your ranking
Apr 07, 2009 | Mach Speed Matrix P4M800 Motherboard
How to disable on-board graphics
when u power upthe computer press F2 or del key to enter in bios.
then go to advanced u seee vga controller disable it.then save settings.
that it
Nov 24, 2008 | Mach Speed P4M800 (890552603480)...
Slow, Slow mobo
Is your CPU set to its correct speed
Aug 18, 2008 | Mach Speed P4M800 (890552603480)...
Boot up problems
The beeps can be either video or memory. Most likely it is memory. Check the memory.
Apr 09, 2008 | Mach Speed P4M800 (890552603480)...
Hi ZJIM, download & run windows vista adviser fro microsoft.
This program will check your system & even your printer if its connected & turned on. After its runs the testing it will advise you what will & will not run with vista. It will also show you where to get updates for your system so you can run vista.
Good Luck!
Mar 25, 2008 | Mach Speed P4M800 (890552603480)...
Mach speed motherboard problem
I had the same problem once. I took it to CompUSA to have them diagnose the problem, and they said I fried the motherboard or CPU. The fans turn on just because your power supply is on.
Jan 14, 2007 | Mach Speed P4M800 (890552603480)...
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
57 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
