The set came in with an open R 702, a 1.2 ohm 7 watt fusible. Since theoreticaly it would take about 6 amps to open this thing I looked for anything around the power supply shorted and came up empty. The hot seems good too. I temporarily installed a 2 amp fuse in place of the resistor and attempted power on. I tried power on at low line too. The set clicks once and that is then followed by another click about 5 seconds later. Power on can then not be attempted again until the AC supply to the set is first momentarily inturrupted. Then the process repeats. The fuse remained intact. This set uses an STR F6626 as a regulator. I have not run into one of these as of yet and it is not listed in my ECG book. So without a schematic I am really at a loss for how to begin to isolate this problem. Is anyone familiar with this set, or in the absence of that could someone please tell me anything about the circuit or perhaps the STR? Thanks, Lenny Stein.
-   Well it's not exactly the same but STR F6626 is involved. A neighbor gave it to me after he stuck an allen key in the power button hole, saw a flash and heard a zap. TV was dead. Turns out he'd shorted R715 which goes right to pin 4 on IC701(STR F6626). Now the IC shows a dead short from pin 4 to pin 5. R702 measures fine but i have the same relay issue you mentioned. A click with power and another click 5 sec. later. My girlfriend has the same TV (27L-S100) and in comparing her set had one click and then picture... I'm also looking for IC701 and it's not my NTE book either. I think it might be both our problems so i'm going to search more and i'll let you know if i find anything. -   Guest
Sanken makes that str ic and it does cause the problem you describe but before you change it look at the pdf from this linkhttp://www.cpcares.com/pdf/STRF6626.PDF Good luck
got a sharp 27 inch tv built in 96. cant turn off the sap. dont have the origional remote. would...
(More)
got a sharp 27 inch tv built in 96. cant turn off the sap. dont have the origional remote. would love to know if there is another soulution to turn it off, sap gets annoying when you dont know spanish.lol
Heyas,
My Sharp Aquos has all of a sudden decided to
show picture for 2 seconds then picture is...
(More)
Heyas,
show picture for 2 seconds then picture is gone
but sound remains.
Remote still changes channels and controls volume but can't see the menu display just a black screen! Any advice for me as kids are getting with drawal symptoms after a week of no TV!
