Televison & Video Logo
Posted on Sep 05, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Curtis Mathis TV
Black Box appears on screen
  • 3 more comments
  • Anonymous Jan 07, 2008
    The black box appears on the screen and we can't get rid of it. It is not on all channels and never during commercials! (weird) We have tried correcting the closed caption as suggested, but it doesn't work. The black box covers the bottom half of the screen making it impossible to watch programming. HELP!
    [email protected]
  • JJTVFan Jun 29, 2008
    Had a big, plain black box covering 95% of the screen, but turning off the Closed Captioning eliminated! (now if I could figure out how it got turned ON in the first place...)
  • mapelisson Sep 14, 2008
    problema e igual.
  • smileym1 Jan 01, 2009
    I pressed some button on the remote... Now I have a black box on the center of the lower portion of the screen. It is not on the program listing channel nor on the commercials. I have pressed every button that I may have hit by mistake... nothing onlyb stays off for about 20n seconds and then returns. We do not have the manual.
  • leross_lrps Jan 17, 2009
    it started with the converter box a few weeks ago. same black box
Anonymous
Level 3:
President:
  • Master 3,130 Answers
  • Posted on Sep 05, 2007
Anonymous
Master
Level 3:
President:
Answers
3130
Questions
5
Helped
1650352
Points
8439
Not a lot of info your giving us, but what it sounds like is the closed caption is on. Take the remote and there should be a button on the original remote unit, or the closed caption is controlled by the menu. Good Luck
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
637
Points
Yes - the closed caption was the problem - perfect solution. thanks
2answers
Curtis Mathis 25" tv 5 years old
hi this is common problem you will find the bulb needs replacing if you still have sound then it will be worth getting done
Nedd to reset TV manually...... remote is not working
I have a curtis Mathis model number cm19102 . I have no remote. It is stuck on no more than 14 channels. Then the word line comes up on blank screen. How can I get it to get more channels
I have a curtis mathes/tronics tv Made in May/2001 Serial no#CM19022S I am trying to hook up a digital conventer box to it and I am having troubles. I also need a users manual for this model and year, pls...
No need for the tv manual.Just follow the basic hook up instructions in the booklet came in with the Converter box.Very easy use channel 3.Use the codes for Curtis-Mathis tv in the booklet for the remote.I hook this Exact model of tv is take 20 mins.
1helpful
2answers
19 inch curtis mathis tv
This is the closed captioning, even though it may not contain writing in the block. If you can access the main menu then you can try and turn the CC to off. Otherwise you are stuck with it.
Please rate this answer if it helped.
SCREEN SIZE
Hi, As indicated by your model number the screen size is 27 inch, which is a common diagonal measurement. This TV has a standard aspect ratio of 4:3.
Lost color on curtis-mathis tv
CHECK FOR AND REDO LOOSE SOLDER JOINTS
1helpful
Black square in lower part of tv screen
Turn off the text box function of the closed captioning.
2helpful
4answers
1986 25 inch Curtis Mathis console tv
I have a curtis mathis console tv with a 8track player, casset player record player and a am/fm stereo, mod number on the box is F607 style TC2 seril number 04787814 new in the box never opened. where can i find out its value?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
