Question about RCA P61310 TV
Convergence My television is out of convergence and when I do the auto converge it says a sensor is not reading
    New Friend:
  • 76 Answers
Sensor not reading problem is due there is some obstruct between sensor and projected light beam. Check any disturbance are there and clean the sensors. Cleaning work is done by the technical persons only since it is sensitive area. Try another method also by changing the TV aspect ratio is 16:9 and then select auto convergence method. This is the one chance is there before you call the technical person
Posted on Sep 06, 2007
SOURCE:
How do i start auto convergence
Press your MENU button on the remote. Move to SETUP and press OK. Then choose Convergence. You should wait until your TV has been on for at least 1 hour before you run the auto convergence. Once the auto convergence has run, you can do your own fine tuning. There will be separate adjustments for Red convergence and Blue convergence. You will use the arrow keys to line up two sets of lines. The instructions will show up on the screen. Good luck, and I hope this takes care of your issue.
Jul 27, 2009 | RCA HD52W59 HDTV Projection Television
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
I see the convergence option in menu but nothing changed
Since you have the convergence options in your menu i would figure that you do not have the common fl231 fuse problem....Now is any part of the picture good. is the picture a bow tie. if you go into red and blue manual option will the crosshairs move up and down and left and right. If you have the bowtie or push in fromtop and bottoml then the likely problem is what is call the convergence power board. if you do have some control over the crosshairs then it may be the convergence amp board. convergence is controled by three diffrent cuicit boards. if you have to replace these boards it may just may need someone like a tech to do a serivce convergence.
Jun 02, 2009 | RCA HD52W59 HDTV Projection Television
Auto Convergence Problem, no menu option, 3d looking picture
yes the board components are out.not to replace whole board only two convergence ic on the board needs replacement. they are not at all costly this link which is mentioned belkow has all the instructions to replace the ic on the board just click it and follow the instructions  http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Mar 07, 2009 | RCA R52WH73 Projection Television
Tiny Mirrors Around the Screen of the Hitachi 51" Rear Projection
OK.. These are photo-sensors for auto-convergence function and without these sensors, auto-convergence function will not work properly.
Jan 02, 2009 | Televison & Video
Screen is pinching
you may still have a fl231 fuse type problem. I would first suggest resoldering the flyback connections. dince this happen ever so often it possible a connection problem. If i had it in the shop i woould chek the flat ribbon connectors also. convergence is controled by three board, convergence power, convergence amp and small signal board. since it pinches this is indication of interuption of convergence power supply. the auto convergence not working. is a symptom of small signal board issues. the small signal board requires specal interface equipment to download data off to place on new board. or the sensors arond the screen has failed.
Dec 10, 2008 | RCA R56WH76 Projection Television
Convergence problem
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle
of the screen. If it is not, use the arrow
Sep 23, 2008 | RCA R52WM24 52" HDTV Projection Television
How can I do Auto Convergence on my 52" TV
The auto convergence should run automatically when activated, If it doesnt you will need to replace the convergence board.
May 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Auto convergence dosent work
if you can line up any then the fuse is not the problem
if you dont have the convergence option in the setup menu it is fuse. DO you have any convergence at all.... sound like it. then this may be a convergence amp board problem. does the cross hair move at all or only up and down or left to right.
Apr 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Loss of convergence after powering off.
you must enter the service mode and align your convergence and save it to the epromm also activate the auto focus to activate the sensors , power on /mute-1-8-2- / press enter to save and before you exit activate the focus key on the remote ,very inportant to do the last step./g
Apr 29, 2007 | Samsung PCN5425R 54" Rear Projection...
RCA P61310 TV Logo
145 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
