Question about Whirlpool LGR3624JQ Gas Dryer
Not working intermittently
I've cleaned out the vent tube, but the dryer is taking longer and longer to work. Some loads have heat, while most are luke warm at best so they never dry. Could this be a problem with the gas flow, maybe a solenoid? Any help is appreciated!
  • 6 more comments
  • Kevin Andersen Sep 07, 2007
    I pulled the vent hose off and verified that the air is coming out full force. I also checked and saw the glow from the burner. However, a load that may have started hot quickly turns cold. Any thoughts on whether the timer switch may be causing this? Perhaps it's faulty.
  • Kevin Andersen Sep 11, 2007
    How quick are the cycles supposed to be? I've noticed that the heat fires up for only about 10 seconds. That doesn't seem right!
    Thanks,
    Kev
  • Kevin Andersen Sep 12, 2007
    Thanks for all the help everyone. Unfortunately, under the mounting pressure of a pile of laundry, I had to call in some local experts! I will however report back what they find this evening.
    Regards,
    Kev
    Indeed, it was the gas coils! Thanks for all the advice to everyone!
    Kevin
  • Srsc66 Nov 25, 2007
    My gas dry is experiencing a similar problem. I replaced the thermal
    fuse and it went again. Here's the situation, the dry turns on heats
    up and then cycles off and doesn't recycle again. Any ideas what the
    problem could be?
  • Anonymous Dec 02, 2007
    My whirlpool dryer heats up pretty well at the start, but then cools and it takes three or four cycles to dry the clothes, I want to repair the coil but can't get the front panel off or order the part. Already blew all vents out with a vaccum reverse and took off the venting system,
    The vents where blown out with a vaccum in reverse the venting removed, and the dryer heats for a few minutes then cools, i want to replace the coils but cant get the front panel off
  • Anonymous Jun 14, 2008
    Kenmore gas dryer 110.76512694 the ignitor lights, burner starts, ignitor starts to cool down, then burner quits and dryer continues to run with out heat unless I restart the cycle.  Which part is faulty?
  • 60 Answers
Also check the gas coils on top of the gas valve odds are if the heat comes on for a little while and shutts off the coils are getting hot and falling out let me know if this works
Posted on Sep 12, 2007
  • 291 Answers
Most of the time... the gas valves work or dont work... I would try taken off the vent hose all together and check to make sure you have a good blow or flow of air out at the exhast of dryer and to see if you are really getting heat out of it. also if you look close in the back thu the wholes back there you should be able to see if you burner is firing or not
Posted on Sep 05, 2007
  • Mike Johnson
    Mike Johnson Sep 08, 2007
    Not sure what u mean... it should reach somewhere around 150 temp. and cycle down to about 120 and back again...
    what temp are u reaching and is it cycleing at all?
    if you have a omh meter.. omh out the thermostate and make sure there good
  • Mike Johnson
    Mike Johnson Sep 12, 2007
    The burner should come on tell the exhast is about 150 give or take 10 degress or so... should take ALEAST a few minutes when empty, will stay on much longer with wet clothes in it.
SOURCE:
Air no longer venting out back of dryer
sounds like the fan not working.
Apr 06, 2013 | Dryers
My dryer seems to be heating up but the clothes take two cycles to dry.
sounds as if the vent is restricted, take vent tube off, dry a load of clothes. Clean vent tube, and you may want to clean the inside of the dryer,also. Hope this helps Tim
Apr 04, 2011 | Frigidaire Electric Dryer
Since a month ago our dryer takes a long time to finish a load, A load which used to take 45 minutes to finish now takes close to 2 hours to finish.
check all of your duct work clean it out make sure there is no lint in the duct work going from the dryer to the wall also check the duct work going from the wall to the outside of the house
Dec 02, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
It takes forever to dry a load of clothes. Drum
Have you checked your vent for blockage? Over time, lint build-up in the vent and in the back of the dryer makes your drying time longer and longer. Unplug the dryer, pull it out and disconnect the vent. Using a flashlight and a vacuum, clean out the back of the dryer that connects to the vent and the vent itself. If you have a long vent line, you'll need to find a away to clean it out to clear any blockage. I use a hand-held plumbers snake that rolls up and pulls out as much length as needed. Then spin it around in the vent to knock off lint attached inside the vent tube walls. It may be easier to do this from the outside, but you can do it from the inside too. Check your outside vent cap for blockage and make sure the vent flap outside is not stuck closed. Also make sure when you push the dryer back into place, that you don't squish the vent tube, if it is made of plastic or foil. After reconnecting the vent, turn on the dryer. The air flow may blow out the lint you have dislodged with the snake. Clean out as necessary at the outside vent. I have a long vent line on my dryer, so I have do this annually. This has helped shorten my dry time every time I do it. Of course, cleaning out the filter regularly, does help too. The more often you clean the filter, the less lint that will build up in the vent . Hope this helps. Douglas
Jul 17, 2010 | Maytag MED5600TQ Electric Dryer
My ge Profile dryer is 5 years old and for about a year the drying process became slower and slower as the heat within became cooler and cooler! Im thinking thats the heating element. My question is how do...
This is dued to lint build up in the dryers venting tubes. If you completely tear the vents off and clean them inside thoroughly it will run like ne again. It will be better to replace accordian stle tubes than to clean them if that is what you have on yours
A moister sensor detects the build up and keeps the heat in check
Jul 01, 2010 | Dryers
Amana les60aw gets hot in dryer but clothes wont dry. cleaned out vent, shortend exhaust hose. noticed an orange glow coming from back vents when i turned it back on???
The orange glow is the heating element working. It mush have good air flow or the coil will burn out and stop heating. Also the thermal limit will stop the heat if to great. If you went all through the vent and the tubing is not smashed or flat check the outside vent for air circulation, if good try to dry a load of clothes. Are you sure your washer is spinning out well? Wet clothes take longer to dry.
Oct 20, 2009 | Dryers
Not heating properly, many cycles to dry loads
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 02, 2009 | Maytag SDG3606A Gas Dryer
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Kenmore elite smartheat quitpak electric dyer
try drying load with vent tube disconnected may get warm and dusty but if works ok recheck vent completely also be sure vent is not being flattened when dryer is pushed back to wall also remove lower panel(clips along top edge each corner about 3-4 inches in)remove blower housing 2-3 screws and clean housing
Dec 12, 2008 | Dryers
Whirlpool LGR3624JQ Gas Dryer Logo
98 people viewed this question
Top Whirlpool Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
