Question about Canon 100 Monopod
Bottom Plastic lever breaks under gentle pressure
The bottom lever for extending the bottom leg, snapped off when I pushed the lever to secure the leg in place. No excessive force was used, as these levers are plastic. I checked online and saw reviews complaining about the same thing happening within the first couple uses of the monopod. Apparently the levers are made of cheap brittle plastic. When rotated, the lever causes a piece of plastic to push against the extended leg, like a brake, locking the leg into place. Otherwise the monopod is very nice. Rather than returning it, I wonder if there is a way to fix it or make a make-shift lever that will lock the bottom leg in place.
SOURCE:
SOURCE: AE-1Problems... Advance lever, Shutter, and more.
This happened to me to both the Canon's I had. I found out it was a dead battery. Once I replaced those it worked fine. The battery is hidden under the hand grip which can be taken off using a coin in the screw slot.
Sincerely,
Karin
Posted on Nov 24, 2007
  • 216 Answers
SOURCE: canon av1 film advance lever will not extend
The AV1 is an electronic camera that has to have a good battery for the shutter to trip. You can find the 6V battery at most drug stores or Walmart
Posted on Dec 06, 2008
cpt100
  • 154 Answers
SOURCE: Automatic aperture setting on canon FD lenses not working on AE-1
You have a case of AE(auto exposure) Unit faulty or getting bad. It suppose to register as it move within the AE unit according to the exposure calculation but somehow it is broken. Technician usualy replace the AE unit and takes care of the problem. It can also be rebuilt if new parts are not available. This requires complete disassembly and mirror box removal. The average cost of repair probably runs around $100. Yes, "A" mode is correct for most of the shots and it was a state of art electronic system and more computerized than you think. It has 3 IC chips in there for precessing and 1 chip for the exposure. All works together for good. -James
Posted on Apr 01, 2009
  • 11967 Answers
SOURCE: Wont power on. Lens was
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 20, 2010
Tri3mast
  • 747 Answers
SOURCE: The Film advance lever wont
Okay this is completely on memory. With the button on the bottom pushed in the camera is waiting for your to rewind the film back into the canister after this is done lift the wheel (not the crank it can break) the wheel is just below the crank and the back of the camera will open so you can take the film out. Reload a fresh roll close the door and advance to the first frame you are back in business again.
Posted on Jan 09, 2011
How to remove cover on indoor unit of Fujitsu aotr30l ct
Undo the screws at the bottom and on the front panel. There may be one behind the power cover as well. You may have to remove the horizontal louvers but be careful because they have a spring or two to assist the louvers swinging and can fly off. When you are sure all the screws have been removed, you will have to use a flat screwdriver to gently lever off the plastic hooks holding the top of the cover to the back - one at each end and one in the middle. Try to see with a torch and be careful not to break the plastic or damage the heat exchanger. The cover comes off best from the top forward.
Also, there may be a couple of hooks under the bottom edge as well. They come loose by pushing up at the bottom edge where the small arrows are.
Jan 17, 2015 | Fujitsu Heating & Cooling
Cork stuck in sharper image wine opener
The black plastic ring is secured on the clear tube that you can see the corkscrew through with four little plastic snap tabs. I used a pair of channel locks to gently pull the ring off those tabs. Once you do that you have access to the inside of the clear tube and can reverse the corkscrew and get your broken cork out. Blow debris out and reassemble. Good as new! Even if you break one tab it should still hold, and if you break multiples use some super glue to hold it in place, that will be your last chance to fix it, but at least you've doubled the life of your toy. Good luck!
Aug 05, 2014 | Home
Remove clutch lever from harley streetbob
Run the clutch cable adjuster all the way down to give the cable maximum slack. Using snap ring pliers, remove the snap ring on the bottom of the clutch pivot pin. Push the pin up and out of the clutch perch. Pull the lever out of the clutch perch. Push the white plastic dowel out of the cable and lever, and you are done.
Jul 31, 2012 | 2006 Harley Davidson FXDBI Street Bob
How do I install on/off switch on Skil Saw 3400
It just pushes in and out. It is held in by plastic legs on the top and bottom of the switch. Reach behind the switch and squeeze on the top and bottom legs to compress them while you push the switch out. The new one will just snap into place as you push it in. Here is a parts diagram if it helps.
Skil 3400 diagram
May 09, 2012 | Skil Saws
How to replace the headlight bulb on 2006 C280?
1. Figure out best way to light the tight area to see.
2.look directly behind the light headlight bulb under hood. You will see a round black plastic cover ...Pull it off. Remind yourself how it came off. It will hook into the bottom and snap back in nicely when you are finished.
3, Do NOT pull off wire connector yet. Note/feel how secure it is for when you replace new bulb.
4. On the outside perimeter of the backside of bulb housing you will see a black plastic round ring (this holds the bulb in)...(there are 2 finger tabs...one for clockwise, 1 for counter clockwise). There is hardly any play to either way...push gently Counter-Clockwise to allow bulb loose.
5. Pull Bulb with wires still attached straight out slowly and see how you will reinsert new one.
6. Have new bulb ready...don't touch bulb glass. Pull off wire connector.
7. Put new bulb on exactly same way onto wire connector
8. Gently house the bulb back the way it came in and hold flush.
9. Now push outer black plastic tab clockwise to hold in bulb...bulb should be as secure as before you took it out.
10.Test Light
11. Put on round black plastic back housing with hooks inserted into 2 two holes on the bottom and press top back its connector and you will hear a secure click.
12. You are done...have a beer...congratulate yourself. Tom.
Apr 18, 2009 | 2007 Mercedes-Benz C230 Sedan
How the hell does the skirt go on this piece of ****?
Put the metal frame on the board - then turn them upside down. The skirt has four slits - where the knobs on the bottom of the board come through - pull the material tautly while snapping on buttons.
Mar 17, 2009 | Kolcraft Light Vibes 18270 Crib
Microwave handle replacement
How to replace handle on GE Advantium SCA1001DSS.
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2008 | Microwave Ovens
Broken switch
That is correct, the flat plastic rod that pulls when you depress the on/off button is attached to a switch lever under the bottom of the handle. The rod in mine broke off right where it connects to that switch lever. You can either try and find the new or used part, Braun may have new, I have not tried their 800 number, can't hurt? I fix everything from scratch though and rebuild when I can especially if parts are scarce or obsolete. So I used some marine putty to affix the rod end back to the lever. Marine putty is a stick with two putties you roll together for a rock hard compound, awesome stuff. You can get at Wally World or hardware, auto parts, boat supply stores. I also drilled very small holes in the broken rod on each side and the lever on each side and threaded some thin stainless steel wire through, just looped it around without twisting it togethor before putting the putty over it for a permanent, wire reinforced, fix.The handle is not screwed on exception of one little torx screw at very bottom of handle on base. The handle just snaps together. The base or bottom and 3 screws do not need to be removed either for this rod and lever fix. Remove the top 'cover' piece of the handle first, then remove the two brass pins under it at top next to the on/off button second. So, the handle 'snaps' off with a lock blade knife or equivalent, get under the handle pieces with knife edge and twist the blade, it will pop off as you go, be prepared to break a few little hook pieces off underneath, they break but it seems to snap back on ok anyway. Crazy glue alone won't hold these plastic pieces together btw, try another way, wire and putty, maybe a plastic welding kit etc.. Mine works great again, once I got the lever reattached to the rod.
Dec 28, 2007 | Braun WK200 Cordless Electric Kettle
Dual Cube speakers
Remove grill from speaker that has the snap connector. Remove 4 screws, gently pull out speaker and padding. Put pressure on connector (making sure the connector is out at the max. position)with middle and index finger at the same time placing other speaker onto connector, slightly turning speaker. You will here it snap in. Just use maximum pressure with fingers. Do not use tools. Connector is made of plastic and can break very easy.
Sep 08, 2007 | Bose Acoustimass 5 III System
Switch problem
That is correct, the flat plastic rod that pulls when you depress the on/off button is attached to a switch lever under the bottom of the handle. The rod in mine broke off right where it connects to that switch lever. You can either try and find the new or used part, Braun may have new, I have not tried their 800 number, can't hurt? I fix everything from scratch though and rebuild when I can especially if parts are scarce or obsolete. So I used some marine putty to affix the rod end back to the lever. Marine putty is a stick with two putties you roll together for a rock hard compound, awesome stuff. You can get at Wally World or hardware, auto parts, boat supply stores. I also drilled very small holes in the broken rod on each side and the lever on each side and threaded some thin stainless steel wire through, just looped it around without twisting it togethor before putting the putty over it for a permanent, wire reinforced, fix.The handle is not screwed on exception of one little torx screw at very bottom of handle on base. The handle just snaps together. The base or bottom and 3 screws do not need to be removed either for this rod and lever fix. Remove the top 'cover' piece of the handle first, then remove the two brass pins under it at top next to the on/off button second. So, the handle 'snaps' off with a lock blade knife or equivalent, get under the handle pieces with knife edge and twist the blade, it will pop off as you go, be prepared to break a few little hook pieces off underneath, they break but it seems to snap back on ok anyway. Crazy glue alone won't hold these plastic pieces together btw, try another way, wire and putty, maybe a plastic welding kit etc.. Mine works great again, once I got the lever reattached to the rod..
Apr 16, 2007 | Braun WK200 Cordless Electric Kettle
Canon 100 Monopod Logo
43 people viewed this question
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Canon Photography Expert? Answer questions, earn points and help others
